smoke pump current draw?
ORIGINAL: furloughed ual
Any one know the amp draw on a typical jet smoke pump at full flow rate?
Thanks.
Thanks.
a lipo of 1500 mah is fine for lots of smoke sessions.
if you count that a typical turbine pumps runs for 30 minutes on a typical 2000 mah battery incl starting.
then a smoke session of 1 or 2 minutes for each flight is nothing compared with turbine pumps
