 how to mix ....... >
how to mix .......
how to mix .......
Old 07-03-2009 | 05:43 PM
Default how to mix .......
I am half way there I can move the rtrm switch and it moves the nose wheel steering now i need to mix rudder with aux 6. can some one Please ,step by step show me how to do it i have never done this before
thanks
Arden
Old 07-03-2009 | 05:46 PM
j.duncker's Avatar
Default RE: how to mix .......
You need to specify which Tx you have - Make and Model please.
Old 07-03-2009 | 05:59 PM
12x sorry that would be nice
thankyou
Arden
Old 07-03-2009 | 06:13 PM
rcjet lynch's Avatar
Enter a pmix does not matter wich one and hit enter, it will ask you hold servos select no, go and select rudder as primary and aux6 as slave, roll the knob to get to the percentages and start to increase the values to get the servo to move also make sure you trimer works in the same direction as the stick.
Old 07-03-2009 | 06:16 PM
You can also turn the mix on and off in that screen if you do not want the servo to move in certain positions.
Old 07-03-2009 | 07:43 PM
something is not right , I selected the first mix #51 I said no and enter program i sellect rudd- aux 6 under pos.0 I input - 50% left and right under pos.1 left at 0% right and left didn't do anything. the servo goes to a hard over but does not stall i can move the servo a little bit with the rudder stick the srvo arm is not at center what am i not doing right
thanks guys
Arden
Old 07-03-2009 | 09:18 PM
Nothing should be under pos 1, both values should be under pos 0 unles you have the mix assinged to a switch. make sure you have your trimer centered as well, but both values should be under pos 0, move the stick the other direction and it will move from the left to the right under pos 0.
Old 07-03-2009 | 09:19 PM
ok i have been trying to get the nose steering gear to go nuetral if I go to device sel and on aux 6 and select inh the steering will go to nuetral if I select the left eyebrow has the same problem so when I select act the servo moves almost full range to one side .
Please anybody out there can help
Arden
Old 07-03-2009 | 09:24 PM
Arden just sent you a pm
Old 07-03-2009 | 09:30 PM
rcjet lynch
that is how I have it set up under 0 -50 for LEFT AND RIGHT and offset at 0 I just changed it to +50 right and left has the sam problem but reverse direction
ARDEN
Old 07-03-2009 | 10:07 PM
CASE CLOSED.... rcjet lynch pm'd me and was able to talk me threw it the problem was a computer glitch of some sort we cleared all programing and started over I had everything programed ok but something would not let the servo center.
thankyou rcjet lynch and to the rest of you guy's .
so when all fails start over
Arden
Old 07-04-2009 | 08:26 AM
Arden, you have have my contact info so if anything else let me know.
Old 07-04-2009 | 08:37 AM
bcovish's Avatar
My Feedback: (8)
Arden
One thing I do and I know a lot of others do it. When you get a model setup in the TX, copy it to a blank model in your TX. That way you will have a backup to restore from if something gets messed. Also use the software that came with the 12X to back it up to your computer.
Old 07-04-2009 | 10:28 AM
rcjet lynch
you know it did it agian when i started to program back in the other channels it did another hard over. but I cleared the xmiter an started over and this time it worked I rebind and seems ok I would hope it dosn't happen when it's barreling down the runway and it would do this the plane probably spin around out of control. not good
Arden
thanks agian for your help
Old 07-04-2009 | 01:23 PM
Arden, what were you trying to mix when it did it again?
Old 07-04-2009 | 01:39 PM
rcjet lynch
I don't remember the sequence but it had to be one of these gear,speedbrake and breaks they all work now but i do wonder if there is a problem with this radio probably me. I may have another problem when i go to wing type i can sellect any of the 4 wing setups but it will not scroll over to the other side to set up for dual elevator etc.... any ideas thanks
Arden
Old 07-04-2009 | 02:00 PM
I will be home from work in a few, I will take a look.
Old 07-04-2009 | 02:20 PM
Arden, which wing mix are you trying to use? Also remember to go to device and inh the aux you are trying to use for the other elevator.
Old 07-04-2009 | 02:59 PM
will do I know they are all active and that may be the problem i will try later as i am leaving to go to a barbecue
Arden
Old 07-04-2009 | 03:54 PM
If they are active that would be the problem for sure.
Old 07-04-2009 | 10:45 PM
rcjet lynch
that was the problem. I inh aux 3 for the duel elevator and it uses ltrm (eyebrow) for trim. I think that will be ok,, also in the monitor the travel for the elevator were going in opposite direction if that's the case when I hook it up in the plane, one elevator goes up and the other down I just will reverse that servo accordingly.
Arden
Old 07-05-2009 | 08:22 AM
Arden, turn off the trimer in the device screen you dont need it, because you did a mate under wing type your elevator trim works both surfaces.
Old 07-05-2009 | 01:17 PM
rcjet lynch
ok , removed it
thanks
Arden
