 Paint stripping help >
Old 07-17-2009 | 01:49 PM
My Feedback: (21)
Default Paint stripping help
Has anyone used Paint Strippers on fiberglass. If so what kind (name brand) did you use . The Glass does have a gel coat under the paint
I have stripped enamels off of glass with Laquer thinner but it is very toxic even with a resporator
Joe L.
Old 07-17-2009 | 02:05 PM
ianober's Avatar
My Feedback: (12)
Default RE: Paint stripping help
I used this stuff on my FB F/A-18F, works like a charm!! I have a build thread that shows how I used it on here.
[link]http://www.eastwood.com/ew-dekote-paint-stripper-1-qt.html[/link]
It took me 2 quarts to do the 18. Best thing about it is that it is water based.
Old 07-17-2009 | 03:53 PM
RCISFUN's Avatar
My Feedback: (44)
Joe....what are you stripping???
A Secrete project?
Old 07-17-2009 | 04:12 PM
invertmast's Avatar
My Feedback: (23)
I've used a chemical called "citri-strip" Bright orange loooking stuff available at lowes/home depot and walmart. I stripped a YA F-18 twin. worked like a charm, took about a quart or so for the entire plane.
Old 07-17-2009 | 04:23 PM
JetCatJimmy's Avatar
How do you clean the solvent off the plane to prevent a reaction to the primer when you repaint? I'm about to strip my BobCat fuse down for it's new colors.
Old 07-17-2009 | 04:24 PM
invertmast's Avatar
My Feedback: (23)
ORIGINAL: JetCatJimmy
I used mineral spirits, and then denatured alcohol w/o any problems.
Old 07-17-2009 | 04:28 PM
Very cool! Thanks.
Old 07-17-2009 | 04:44 PM
FL510's Avatar
My Feedback: (8)
I used "klean-strip" fiberglass stripper. Worked really well.
Jed
Old 07-17-2009 | 06:30 PM
All types of paint strippers I have used have been neutralized with water.I usually use water and a scotchbrite pad.Just make sure the stripper is fiberglass safe.
