Reload this Page >
9303 2.4 KingCat Setup Question
Old 09-27-2009, 11:34 PM
bob1393
My Feedback: (10)
bob1393's Avatar
Default 9303 2.4 KingCat Setup Question
More radio questions for the experts out there:
1: In "Wing Type" (set at "Normal") I want to use dual servo dual channel for ailerons and elevators. I only get one choice for the slave channel - Aux 2 for the
aileron slave and Aux 3 for the elevator slave. Why do I not get other choices? I'll explain why in a moment.
2: In "Device Select" - Aux 2 and Aux 3 give me the option of using a slider/lever as one of the devices. Aux 4 does NOT allow me to use a slider/lever as an option.
Does anybody know how to change this to allow me the use of a slider on Aux 4?
I'm trying to put my brakes on a proportional channel - specifically the right hand slider - and Aux 4 is my only open channel. From no. 2 above you can
see that I am unable to do that.
If I could switch Aux 2 or Aux 3 for the second aileron or elevator channel to Aux 4 instead, that would free up either Aux 2 or Aux 3 and they do allow the use
of a slider for that channel. But this is also impossible - see 1 above.
Anybody with a solution for me?
Thanks - Bob
Old 09-27-2009, 11:45 PM
SinCityJets
Default RE: 9303 2.4 KingCat Setup Question
Bob,
Go to DEV SEL and INH Aux4. That should free it up to be used as a dual channel.
Chad
Old 09-28-2009, 02:13 AM
bob1393
My Feedback: (10)
bob1393's Avatar
Hi Chad - good to hear from you. I did what you said but nothing has changed.
Bob
Old 09-28-2009, 09:45 AM
SinCityJets
Bob,
PM your number. I'll call you later this evening.
Chad
Old 09-28-2009, 10:24 AM
John Redman
My Feedback: (8)
You will need to INH Aux 3 as well. This now enables the slider on the right hand side of the transmitter to come to life in a p-mix to do what you would like.
Old 09-28-2009, 12:16 PM
bob1393
My Feedback: (10)
bob1393's Avatar
John and Chad - thanks for the help. I got it working. I already had Aux 2,3, and 4 INH, but I did not have a P-Mix. I used a P-Mix - RLVR to Aux 4 - and now the brakes
work on the proportional RLVR. Thanks again.
Bob
