Weatronic 2.4 RF diagnostic tool
#2576
Oli, and all the others,Thanks for your advice here is another question on the BAT60.
I have the ailerons going the correct way, but if I try crow, or butterfly one goes up and the other down, whereas of course they should both move the same way.
Where in the BAT60 do I find the details to make them work in the correct manner.
Regards
Ross
Regards
Ross
#2577
Has anyone tried a BAT60 in the direct sunlight. This morning I was trying to set up the Nimbus and the screen is totally unreadable.
I then checked with my Samsung Galaxy tab 2 and that screen is fully readable and so is the screen on my Graupner MX24s.
Not being able to read the screen on the BAT60 will be a real difficulty if trying to read the telemetry.
Comments
Ross
Comments
Ross
#2578
Hooking up a jet engine.
I have been flying my Tuono jet with an IQ Hammer (with Projet ECU and terminal) successfully for two years now. With an older Futaba FC28 /DV3 module, but a 12-22 receiver.
Now I am converting to an FX30/DV4BT and I cannot get the ECU programmed (Throttle/trim positions), after the last entry (Full throttle signal) it botches. I tried many settings in GC and the Xmtr, like steepening or flattening the servo line or reversing it. No joy.
I wonder if any jet pilot has had problems also with setting up a jet engine?
#2579
Hi Ross,
in _direct_ sunlight, it might be a problem to read the display clearly. For me, it helped when I moved myself in that way, so I get some body shadow on the display. The problem only occurs in direct sunlight for me. Reading the relative big numbers for telemetry is not so difficult as looking at the fine graphs for setup; at least for me...
Simple Mono-LCDs do not have that problem; but if I had the chance to choose if I want to have a YETI-TX-Style mono display (regardless of its bad resolution) on may BAT or the Hi-Res color LCD... you know the answer ;-) Samsung is a premium display developer/manufacturer and hardly to beat. The development continues rapidly. I think there will be a "revision 2" of the BATxx in some non-specific time from now, which will have an again better display fitted, beside other improvements. That is the normal evolutionary way with high tech electronics; see cellpohnes etc. But that doesn´t irritate me. All other options would mean that there is no development :-)
best regrads from germany
Tom
Tom
#2580
After 2hrs more trouble shooting I could solve the problem
After nothing seemed to work, I finally reconnected with the old Xmtr, lo and behold, it worked still, the engine reacted after passing again through the learning menu.
I copied the readout on the ECU terminal and connected the new FX30/DV4BT again. Watching the data on the ECU Terminal in the engine learning mode I fiddled around with both the WEA Software and the Xmtr Endpoints, so that I got the same values as with the old setup.
Which value was not OK previously I dunno, anyhow these values work, so if someone else runs into the same problems with a Projet ECU, try these:
Trim and Throttle both CLOSE: 2847/0.6ms
Trim OPEN and Throttle CLOSED: 3493/0.8ms
Trim OPEN and Throttle OPEN: 8403/2.1ms
#2581
First, can you send a picture of how you did setup the crow function?
#2582
Sorry Oli, that is one item I am still trying to work out how to get crow.
Changing the subject slightly, in order to set up each wing surface do I need a function set up for each surface, (as in gigacontrol) whereas butterfly combines both flap surfaces.
Your help is greatly appreciated.
Ross
ps: Tom, re the screen you are correct, but I am surprised that there aren't better screens available.
Ross
#2584
Hi Oli,
I probably have 2 questions, (well possibly more as I work my way through the BAT60) , but lets keep to one question first.
Each wing has 4 control surfaces, (plus airbrake of course),2 ailerons 2 flaps, with a servo on each. I am using mode 1 with the airbrake and flap control
on the "throttle". I have the airbrakes mixed with the flaps and that works well.
My problem is as I move the stick towards me, the flaps should both go down together. This works perfectly on the right wing, both the inner and outer flap move
downwards, but on the left wing the flaps are in reverse, and move upwards. not what I want.
So how do I make the left hand flaps work correctly?
I have tried changing the direction of the flap in Curve edit but this does not work.
So what am I doing wrong.
Regards
Ross
Regards
Ross
#2585
Hi all, after much effort and learning about the BAT60, I now have a Paritech Nimbus 4 with 15 servos, and 2 micro 12,s all programmed. It has taken a lot of time but it now all works as it should. The advice about using an ammeter helped a lot.
I know a lot of effort has gone into the programming by the programmers at Weatronics, and they have made a fine product yes there are still improvements to come which should make programming of individual models easier.
best wishes
ross
best wishes
ross
#2586
Rechecking the control surface movement, I noticed that the left 2 ailerons were not moving as much as the right 2 ailerons, even though they were all set up together.
So a question; should I set up a separate function for each aileron or possibly group the 2 left ailerons in one function and the 2 right in another. That would enable me to adjust
each aileron separately (or 2 as a group). Note Gigacontrol has this facility as you can adjust each aileron separately.
Your comments please.
Best wishes
Ross
Best wishes
Ross
#2587
My Feedback: (13)
Got my Bat 60.
Started to setup a prop trainer for testing. The hardware is ok for me, with the exception maybe of the rocker switches. I'm not sure if they are two positions, or three positions (when setting them for a function, they seem to be 3 position but can quite get the middle one).
Tried to setup a timer, but no luck. After selecting the start,stop and reset switch, the timer does not do anything. Any idea?
Also,anyone knows if the timer can work (or will work in the future) with the throttle stick as a control? That a great feature of Futaba.
Lastly, do we have to wait for a new firmware to be able to use the integrated gyros and mux box? There is not screen in the transmitter for those.
#2588
Edgar, you can control the timer through the throttle. First you need to create a virtual switch with the throttle. Then you assign the timer start function to that virtual switch. You can adjust the trigger point on the throttle through the virtual switch settings. Hope that helps.
Woody
Woody
#2589
My Feedback: (13)
Hi Woody,
Thanks for the pointer. I was able to setup the virtual switch. However my timer still don't want to count. See photo with timer start control activated and another with the stop control activated. Evidently I'm doing something wrong.
Also I noticed that one fo the transmitter Lion cells is not the same capacity as the other ones. Is this normal?
Thanks!
Thanks!
#2590
Hi Woody,
Thanks!
Thanks!
Try deleting the timer and re program. It could be that you forgot to high light a feature. Easy to do as I've done it several times. Sometimes it's just easier to delete and try again.
I've not tried it with 2 virtual settings how you have displayed in your pictures. Set your off control to fixed in the off or on a switch and see what happens.
If you tell me what type of timer style your trying to set up I can try it on my BAT60 and pass over how I did it.
I'm running all my timers with a virtual switch set on my throttle with enough stick movement for taxi until it starts to count. I'm not running a stop control and for reset I'm using a rocker switch. Very basic and been working fine.
Let me know how it goes.
#2592
Hi,
it is NEARLY the same software and a completely different housing of course. Those differences are the reason why there is a delay. Talked to Weatronic a few days ago,the plan was to deliver the BAT64 in december, but I personally think it will be end of january 2015. I am waiting like you for the BAT64 and ALREADY HAVE a BAT60. The BAT60 shows me clearly that it is worth the waiting for the BAT64 ;-)
best regards
Tom
best regards
Tom
#2593
My Feedback: (13)
Orlando,
I tried making a new timer without using any virtual switch. No luck. I recorded a video of it.
https://www.youtube.com/watch?v=muAoOMSQDzM&index=4&list=WL I have also tried doing a hard reset prior and doing a count-down timer. Same result. Im really confused here
Thanks for any help.
PD: I opened the BAT ans noticed that all my four batteries are the same, so it must be the Weatronics system holding some charge at reserve why one is showing 3000 mAh while the others show 4400 mAh
#2594
Thanks for the video. We had one of our demo BAT60's do the same thing.
I'm in the impression that your BAT60 has been updated with the latest firmware. I've attached a pic of firmware page
Try this. Delete both your timers. Re-do it again. This time add a value for it to count down. Maybe 1:00 minute. After you have set it up the way you want go ahead and shut the radio down. Then re-start.
This is what worked for one of our demo radio here at the shop.
#2595
Thanks Tom, waiting with excitement... ;-)
Hi,
best regards
Tom
best regards
Tom
#2598
My Feedback: (13)
No SD card in the radio (although I have previously put one in, and the radio froze in the boot, so had to hard reset it).
The timer functionality is buggy, as many times new timers come with no value in the 'current value' field. At that point no matter what parameters you put, the radio wont count. Following Orlando advice I was able to get a few times a value loaded and the timer working, but it will stop counting after a while. Subsequently, the current value will go back to unspecified (instead of 00:00:00 or any other value) resulting in an unusable counter.
I got a good setup with my Futaba 12FG/Wea combination, so not in a rush. Wanted to start testing the BAT 60 in a prop trainer. I can wait for Wea to fix.
Another 'bug' (or misunderstanding on my part) is that when going to the switch assignment screen, a 3 position switch that is in the middle position, will show as activating both the middle and one of the other positions (example, middle and bottom position, as per the blue box highlight). A 3 position switch should only have one blue box highlighted in the screen depending on the position of the switch itself (up, middle or down).
#2600
Hello to all weatronic user, followers and anyone else
Hello Edgar,
we know the deficit withe the Timer Current Value = -.-
Please try to choose at the Alarmtype not the Voice. So select Beep or / and Vibration, but not Voice or only Voice. Then restart the Transmitter. Now the deficit should be fixed.
If not please inform me.
The Battery capacity wil be calculated. After 5 - 6 Charging cycles it will be correct calculated. or you switch you transmitter on and
leave it so long until it switches off. Then load the Transmitter until the LED Ring is green, not yellow. Then switch the Transmitter on and the Capacity will be right.
Kind regards from Berlin / Mit freundlichen Grüßen aus Berlin
Jens Ackermann
Leiter der Serviceabteilung
Hello Edgar,
Jens Ackermann
