A123 cell charging
RE: A123 cell charging
Chad
thanks for that. I'm really surprised this charger has this option as it must be 4 years old and I didn't think these A123 cells were about then.
thanks
Jason
thanks
Jason
That's pretty much the beginning of A123's for hobby use. If it's not a balancing charger, you may want to get one. While it isn't as important as it is with lipo's, and they won't burst in to flames, it does extend the life of the batter and let you get the most mah out of your batteries.
Good luck!
Chad
Good luck!
Chad
My Feedback: (10)
OH
You can also use a Blinky made for A123s http://www.espritmodel.com/index.asp...OD&ProdID=5672
ORIGINAL: madmodelman
Chad, talking about balancing, do you know what balance plug is on the standard 2S Jetcat lipo's please?
Graupner/Robbe plug for balancing
FWIW and regarding balancing, I use my standard Thunderpower balancers to balance my A123 packs. This is possible because the balancers start working at a voltage below the max voltage reached by A123s on charge. It's likely that other makes of stand-alone balancers will also work.
Gordon
Gordon
My Feedback: (39)
PA
Hi Guys,
I have 4 Triton chargers I use for everything so far. Can I use these for A123 if I plug something in between ? OR, do I need to buy another charger .
Dale
Dale
Be careful when choosing a balancer. A lipo balancer will not work properly, as the cut off voltage is too high. Most chargers work by DRAWING power from the high cell. The reason I use (and sell) the FMA Cell Pro is it PUSHES power to the low cell, AND it actually charges each cell individually through the balancing connector.
I'm sure there are other decent chargers out there, this is just what I use.
Chad
Chad
I use the CellPro 10s and its awesome.....period !!!!!!!
George
