Mibo leaking gear cylinder fix
My Feedback: (40)
RE: Mibo leaking gear cylinder fix
Nice video, thanks for posting it.
My MIBO cylinders leaked because they were slightly "ovalized" (not round) and would leak or not as the plunger was rotated to different positions. The only fix was to replace them.
Due to the tendency of these cylinders to leak from a variety of locations, I conclude that the design and/or manufacturing tolerances are inadequate.
Craig
Craig
The problem you describe was due to a bad batch of cylinders from Jet A-1. Mibo replaces these free of charge if they are contacted and the product is sent back. Jet A-1 told Mibo that the problem is now fixed. I had this problem with a set of gear and the cylinders were replaced promptly.
Mike
Mike
My Feedback: (35)
The cylinders/kits that Craig and Dave are referring to were G3 kits that were deliver over 4 years ago.
The clients that have more recent kits are advised that the fabricator of the cylinders have changed twice since Dave's and Craig's kits. Should any of you have a problem do the Wayne fix or return them to me for a fix or replacement? We have had 3 sets of later vintage cylinders to leak and all 3 have been successfully fixed with “O” rings.
Thanks to Wayne for locating the leak and determing the fix in some of the plungers.
My Feedback: (29)
ORIGINAL: P38J
Here is a video I made showning how to fix the retract cylinders for the Mibo A-10 if you have a set that are leaking.
[link=http://www.youtube.com/watch?v=1uE8dpc71zk]Cylinder fix video[/link]
Nice video thanks.
Ron
