View Poll Results: A poll
Voters: 194. You may not vote on this poll
What size engine - A poll
[/quote]
Model Turbine engines have a long way to go before they reach the level of perfomance that can and has already been achieved in 4'' diameter sizes. I have seen compression ratios of 6:1 and 300N thrust at FSC of 0.02 g/N/s in KJ sized package, using ceramic NGV and turbine, 600N with 2000 deg EGT.
Mainly the compressors and diffusors are radically different from the current CFD ''optimised'' designs. Combustors are simple but also very different.
Andre Baird
[/quote]
Will this technology make its way into model turbines and at what price?
NJ
ORIGINAL: Bob R2
Andre Baird
Andre Baird
Supersonic compressors are neat but have their limitations in our use.
Some might
My Feedback: (57)
ORIGINAL: Gaspar
Maybe something like this? http://www.jets-munt.com/pb/M140/M140.html
Gaspar
ORIGINAL: FalconWings
We need a Jet Central Rhino thrust class sized like a Falcon. Kind of like a Rabbit technology based Falcon.
Gaspar
I prefer the teeny ones
You dont see this engines as much as the big ones.
I build two 40rs engines ,they are 65mm o.d and i realy like them.
i think they are much more fun to build then kj66 type
My Feedback: (39)
ORIGINAL: Harley Condra
Paul,
The major players are able to invest in R&D effort that is unaffordable by the model engine companies.
That wheel is from a Teledyne Continental 373-8C turbojet (940 Lbs of thrust, using 1980's technology). I was first introduced to this engine in around 1986.
I took the attached launch photo in 2001 at Kom Aushim AFB, (Egyptian Air Force) southwest of Cairo, Egypt.
The booster burns for 4.5 seconds, produces 4550Lbs (nominal) of thrust, when combined with the engine's 940 lbs of thrust, accelerates the UAV from zero airspeed to over 400 Kts at booster burnout and drop-off. The UAV weighs 2356 Lbs. gross.
When the booster ignites, it is Hellfire and Brimstone!!
Paul,
Turbines of any size are COOL! [8D]
#31
ORIGINAL: erazz
Some might and some probably won't. The only ceramic material I'm aware of that has the required strength to withstand the stresses of rotation is carbon-carbon. The same material that makes up the leading edges of the space shuttle. Really expensive stuff.
Some might
ORIGINAL: Bob R2
Andre Baird
Andre Baird
Some might
The truth is current compressors barely works as it is. CFD tools available to the public are not good enough to hint at this. Their flow predictions are just way wrong.
Andre
#32
NJ
ORIGINAL: Turbotronic
A lot of reasearch has been done in the last 5 years which has turned conventional wisdom re compressor difussor design on its head. Some of it was known decades ago in the soviet block and has found its way into small missile engines. There is no reason why a reworked design with the technology we already use cannot produce 240N in a KJ size engine with close to half the fuel consumption. Its a question of know how. Add ceramics and youre talking 600N...
I agree that there are some really nice innovations in impeller/diffuser designs.
The problem (for us) is the use of ceramics. The current trend for turbines is to use Silicone Nitride and hot press it under high pressure (Hot Isostatic Pressing). While the process itself is not terribly expensive when compared to vacuum casting Inconel the bare materials are still very expensive. Plus any FOD that enters the engine will instantly turn that expensive turbine to dust. All in all the technology has not yet matured to the point we can reliably use ceramic turbines. I'm tinkering with this on-and-off. I promise to tell if I hit on anything
As to the thrust figures - we're probably very close to the limit of what you can get in terms of thrust. 240N of thrust from a 70mm impeller will require almost 100% efficiency of the compressor stage. I doubt it's possible but I'd love to be proven wrong. Going to ceramics can increase thrust twofold. 600N from a Kj sized engine is probably not possible.
#33
Erazz,
Its not a question of being proved wrong, its been done 15 years ago already. Ansys CFD gets it wrong too... New tools being develped right now are improving the situation but advances in laser velocitromy has divulged the true flow problems in non-axial compressors. While is is true that when the problem is set up incorrectly the best CFD fails, predicting initial conditions is very important. I know a lot about the subject, more than most small turbine builders, but it is nowhere near enough to form an opineon of what is possible and what not. So I rely on what has been done as a guide.
I am reminded of the NASA propultion enginners that refused to believe a specification for a rocket motor developed in the 60's in the USSR. When they observed it during tests exceeding the spec they realized they were 40 years behind... Many military /research rockets now use this motor under licence in the USA...
Andre Baird
Andre Baird
#34
ORIGINAL: eric_monster
Nice to see some variety here. I was starting to think that the P-200 was the only turbine in existence now. LOL
Eric
Eric
#35
ORIGINAL: Didier
Did you know that the internal of the JetCat P-200 actually is a copy of the legandary first generation AMT NL Olympus?? ;-)
Eric
Eric
#36
NJ
Yeah, engineers get stubborn. Good thing I'm not an engineer!
BTW. Do you have any link or articles that deal with these new impellers and diffusers? I'd like to read about them.
#37
No public info has been released AFAIK from the specific company. I do have the info but I could not release it since it is copyrighted.
I can say that the diffusor has no vanes as we know them. The compressor is mixed flow and has a lot of backsweep right from the inducer end already. It runs at 120K and has a press ratio of 6:1
#38
Did they copy the reliability as well?
ORIGINAL: Didier
Eric
Eric
