Wanted!
CA
Hello all.
Does anyone has the old gold ECU for the Air (Auto Start) for the 2250 Simjet engines that he or she would like to part with.
I am looking for a replacement and due to economy, I can not have it up graded to the latest versions of full Auto ECU. Thank
you gents.
you gents.
ORIGINAL: yf222000
Hello.
What's the rating for your ECU? I am looking for one that runs the 22.5 lbs engine. Thanks for the response.
Hello.
Hi,
Mine's for 85N. Guess that wouldn't fit your requirement.
Brgds
Henry
Hello:
Why you no use the FADEC of Gaspar in autostar version ???
I use in my simjets and work perfect.
Carlos.
__________________________________________
http://cmjets.blogspot.com/
Carlos.
CA
Hello.
I stayed with the air start, because i have all of the support equipment here readily. Also, for some reason, I like
the simplicity of the old air start turbine. I thought about upgrading it to full auto sequence, but the other half didn't
like the idea too much, especially with this tight times. I am sure many understand what I am saying.
Perhaps
when things picks up again, then the idea may get pass by the "accountant"
Perhapswhen things picks up again, then the idea may get pass by the "accountant"
