 Harpoon 2 Help >
Harpoon 2 Help
Harpoon 2 Help
Old 12-18-2009 | 12:12 PM
Default Harpoon 2 Help
I am just finishing off a Harpoon 2 which i bought second hand,
i don,t have any instructions so i would like to know the flight control settings
c,g, control throws, expo & any other info you think might be of use.
Many thanks.
Rgds Martin.
Old 12-18-2009 | 01:02 PM
Default RE: Harpoon 2 Help
Martin
Mine is
Aileron 15mmdown, 17mm up expo 25-30% to soften
Elevator 25mm down, 27mm up Expo 20% (softish) both measured inner pair TE All moving as one
Rudder 10mm each way
Canard much as you like
C of G I think is 125-130mm infront of spar...nose heavy is better
With vector tube no reflex...but willequire trimming on separate channel subtrim
Graupner.de I think has instructions to down load and c of g check
Dave
Old 12-18-2009 | 04:44 PM
Cheers Dave.
Rgds Martin.
Old 12-18-2009 | 06:45 PM
BaldEagel's Avatar
Martin
Instruction should be here: http://www.graupner.de/fileadmin/dow...n2_de_gb_f.pdf
Page 42 onwards are the pics and English text.
Mike
Old 12-19-2009 | 04:41 PM
Thanks Mike.
Rgds Martin.
