Habu in UK!!
#226
AB, CANADA
RE: Habu in UK!!
We had a customer who wanted the Habu, but not in the same colours as all the others...so we painted the yellow white...
Read more: http://www.rcuniverse.com/forum/m_93...#ixzz0sShSajzt
Why stop there???
#230
RE: Habu in UK!!
ORIGINAL: Dave Wilshere
D
Clevis keepers are fine I can assure you I've tested them...
The wing fit is not helped by the fan ''notch'' in the wing which does not always line up exactly with the fan unit. I now put the wing on, press down and the foam marks enough to know where to trim.
Two leads are a must for me to tweek differential, hence I threw them in. Make sure you mix rudder/aileron opposite approx 8% for perfect KE.
One of the others I sold at Honnington was flown tonight and the happy owner emailed me saying wow! I'm sure you will enjoy it, should be warm at the weekend, but keep the cells warm, the difference is huge! Oh and make sure the pack is fully strapped to stop it lifting and ''popping'' the canopy
Dave
D
Dave
I got one last week, just popped it together. Done the screw/rawl plug fix, still wont close…
Ah ha! The fan notch! Will look at that when I get home tonight and trim, thanks!
What % aileron differential are you using?
In all the years I’ve never mixed out the push or pull tendency at KE… It’s about time I started!
I’ve got my last seasons trusty TP 45C 4s 2650 and brand new TP 65C 4s 3300 to use with it. The new TP’s fit the battery space perfectly.
Alex
#232
RE: Habu in UK!!
ORIGINAL: Like2fly!
Hi,
Alex
D
Dave
D
Dave
Alex
Dave said opposite aileron on KE, the Habu will roll out of knife edge when you put in rudder, tucking is neutral, if you get some its possibly C of G and not aerodynamics.
Mike
#237
RE: Habu in UK!!
Why would they take a step back?[] Stock servos have been great in hundreds of flights, never change the trim on either of my Habu's
Dave
Dave
#238
RE: Habu in UK!!
i always found hitec hs 65 mg or hb preferable, had a aileron servo on my t 28 fail, causing a crash. had one fail (another parkzone one) that i put in a jetiger edf to, and caused a roll in to ground during a high speed pass.
#239
RE: Habu in UK!!
We have sold 60+ Habu's and have 10+ in the local club, none have had a problem I'm aware of. HS 65. One of my employees put some in a Fun Fly electric model...felt like rubber pushrods and never trimmed!
#240
RE: Habu in UK!!
really, well that food for thought[X(].... well i hope you never do hear of any problems.... just seems odd, that i had two fail recently, and both were parkzone ones. any way, such is life. were in watford? i used to live there, near borehamwood, and the only place i knew to get planes was hobbystores in stalbans.? any tips for someone new to the habu at all?
#241
RE: Habu in UK!!
It will fly tail heavy with the 2650 4s
No push or pull on any I have flown...
Dave
Dave
Alex
#242
RE: Habu in UK!!
ORIGINAL: collective itch
#243
RE: Habu in UK!!
Habu is a great model. Flys much better without the U/C. Solo hand launches are fine..if you can throw level! Hold the model just in front of the inlets and support it on your index finger as you launch. You can stand still in all but calm conditions! It will slow up fine without anything nasty, most are damaged by landing too fast!
Dave
