Smoke pump question
Get something like this:
http://www3.towerhobbies.com/cgi-bin...&I=LXHUY9&P=SM
Pull or cut the red lead to the Rx to disable the BEC power input, match connectors to the motor, add a battery and you're there. I usually swap over to the red JST connectors for the motor side. Check the specs, some of these GWS ESC's have proper lipo cutoff voltages so you can go with a 7.4v 2S pack.
That's the setup I use with old fuel pumps. Easy and inexpensive.
My Feedback: (49)
That's exactly what I did with my old Ram 500 pump. The nice thing about it is that you can run the pump at whatever speed you want. Initially I put it on a slider to find the right amount of smoke without emptying the smoke tank too soon. Now I have it mixed with throttle and use a mix switch to turn it off and on. It works great.
Joe
Joe
