 Converting thrust figures to ISA standards >
Old 01-20-2010 | 04:28 PM
SAP_2000's Avatar
Default Converting thrust figures to ISA standards
Anyone have the formula or an (easy) way of converting thrust figures to ISA standards (sea level, 15c and 1012 hpa i think)
For excample:
Meassured thrust is 100N at minus 4 degC, 1032 hpa barometric pressure and at 150 meters elevation.
Thanks![8D]
Old 01-20-2010 | 05:20 PM
My Feedback: (39)
Default RE: Converting thrust figures to ISA standards
Stalle,
Type in "Density altitude calculator" on a search engine...I believe it is a thrust loss of 1.8% to 2%
per 1000 feet of density altitude.
Old 01-20-2010 | 07:02 PM
SAP_2000's Avatar
Thank you.
With the figures I typed in to [link=http://wahiduddin.net/calc/calc_da_m.htm]this calculator[/link], I got a relative air density at 106,98%
Am I right to assume that in the tested enviroment (-4c and at 152 meters ASL) you get a thrust that is 6,98% more than at 15degC at sea level, so to convert to ISA I should subtract 6,98%??
Or is it more to it??
Old 01-21-2010 | 02:38 AM
Gaspar's Avatar
At -4C and 103200 Pa you will get around a 9.1% more thrust.
Gaspar
Old 01-21-2010 | 03:23 AM
SAP_2000's Avatar
Thanks Gaspar!
I did meassure the athmospheric pressure. It was 1032 hPa.
Can you give a link to the calculator you use, or tell me how you calculate to get the 11% result??
I having some issues with an engine that is not performing as it should...
Old 01-21-2010 | 04:28 AM
Gaspar's Avatar
Hi Staale,
sorry, made a mistake, it is a 9,1% more, have corrected my previous post. The formula is simple, but don't remember it right now, I have it embedded in a software to calculate all engine performance that I wrote many moons ago (likely 10 years)... Feel free to ask for any other conversion.
Gaspar
Old 01-21-2010 | 05:47 AM
SAP_2000's Avatar
Sent you a PM...
Old 01-23-2010 | 12:12 PM
Hello Gaspar,
If you are willing to convert this also:
110N (at 123 000 rpm), air humidity 96%, air pressure 987 hPa, temperature 1 C and altitude 40 m above sea level.
This was reported by Uwe Kannapin when he did a maintenance to my Simjet 3000 last month. Factory says that this turbine should be 135N.
Thank you.
Kalle
Old 01-23-2010 | 03:47 PM
Gaspar's Avatar
Hi Staale,
Nothing received by PM, please use email.
Kallle, a engine of 112,6N ISA will give 110N at 1C and 987hpA
GAspar
Old 01-24-2010 | 10:40 AM
Thanks Gaspar.
Have to say that my Simjet 3000 is then something else than 135N turbine... Missing 17% of the thrust that factory rates for the turbine.
Old 07-30-2010 | 09:03 PM
My Feedback: (10)
Sorry to dig up an older thread, but I am having difficulty trying to find the formula for this conversion... if anyone has RCJI issue 51, it is supposed to be in there, and can you post it?
I am trying to convert the following to ISA values:
Thrust of 163 N (16.6 kg), temperature of 25 C, altitude of 316 M above sea level, pressure of 101.72 kPa, relative humidity of 43%
Andrew
Old 07-30-2010 | 11:56 PM
furloughed ual's Avatar
My Feedback: (31)
We've measured several different turbines from different manufactures and find that we lose approx 4% per 1000' of Density Altitude over the manufacturer published numbers....so at 6000' DA, all turbines tested were putting out about 75% (or a 25% loss) from the published thrust figure at SL. FWIW.
Old 07-31-2010 | 09:39 PM
My Feedback: (10)
No one has that issue of RCJI??
AJC
Old 08-02-2010 | 08:40 PM
My Feedback: (10)
BUmp... someone here has to have issue 51 of RCJI?
AJC
