Turbine pipe question >
Old 04-03-2002 | 03:49 AM
Jetset's Avatar
Default Turbine pipe question
Just curious to know how the arrangement of the exhaust pipe is in relation to the turbine. Is the pipe actually attached to the turbine or does it sit back a bit from the exhaust.
This is assuming the turbine is inside a fuselage.
Thanks in advance for the input everyone!
Myles
Old 04-03-2002 | 11:26 AM
The pipe sits back a bit to allow bypass air to be sucked in the front of the thrust tube. An article in RCJI, about half a year ago, showed that, in the particular installation studied, the nominal longitudinal gap between thrust tube front and turbine rear was, I believe, .25".
Old 04-03-2002 | 01:38 PM
Default Gap
Hi Myles, Mark
Mark is correct. It's about a quarter inch. Myles. e-mail me your snail mail address and I'll send you a copy of the article.
Ed
Old 04-04-2002 | 05:03 AM
rcav8tr
hi can you send me a copy of the RCJI article on turbine trust tubes i just got a turbomin turbine and it would be a great help as i need all the help i can get
send to [email protected]
