How to recognize older AMT?
NE
Is there an easy way to determine the model number of a older AMT turbine? I have one I believe to be circa 2002, ESU say's AMT on it, airstart, uses large round plug for GSU/starting, but I can find no marking that would indicate which model.
-John
-John
My Feedback: (38)
There is usually a serial number engraved around the edge of the cap. If you plug up everything, it will read out on the edt which engine it is. What diameter is it?
NE
Unfortunately, I personally don’t have the ground support equipment necessary to read as suggested. I found the SN. The can diameter is 4”, one piece (less intake ring), exhaust is 1.75”.
My Feedback: (29)
John:
It surely is a Mercury because of the diameter, the serial number and model should be on the ECU if I'm not mistaken, at least the model number, I have a Pegasus from 2000, yours looks old because of corrosion on the aluminum intake cover...
hey geronimo I tried responding to your PM's but it says you can't recieve PM's. can you email me [email protected]
