Reload this Page >
Jetlegend Mig 29 Fulcrum
Old 03-10-2015, 03:18 PM
  #626
mikedenilin
My Feedback: (67)
As long as you can keep thrust at 36 lbs or less, it would handle fine, but I recommend that you replace the pipe when it reaches 75 flights or more or when you have a few hot starts. The bifurcating center area seem to develop leaks or voids overtime. That's the area of frequent inspection. I had it happened to my F-15s a couple of times but that's after 100 + flights each. Since they share similar metals and constructions and from the same source. I had head shield right above the joint so the hot gas won't melt the fuselage.
Mike
Old 03-10-2015, 04:56 PM
  #627
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Thanks!
Old 03-23-2015, 10:46 AM
  #628
Jesus Cordoba
a few months working on the mig29......
...The HF aerial...
...Nose electronics ports correction (12-9 version) and temp. probe...
... blast suppression air ducts....
...cannon bay venting air louvres...
...Upper surface air intake louvres/suction relief doors and intake spill air louvres...
...ILS, IFF and UHF....
...correction Nozzle...
...and beginning the paint scheme...
ID:	2083635   Click image for larger version
ID:	2083636   Click image for larger version
ID:	2083637   Click image for larger version
ID:	2083638   Click image for larger version
ID:	2083640   Click image for larger version
ID:	2083641   Click image for larger version
ID:	2083643   Click image for larger version
ID:	2083647   Click image for larger version
ID:	2083650   Click image for larger version
Old 10-11-2016, 07:46 AM
  #629
Edgar Perez
My Feedback: (13)
Looking for a cockpit kit options for this plane...
Old 02-16-2017, 11:54 AM
  #630
DornierJet
My Feedback: (91)
i3dm,
glad to see you did all the hydraulic mods on that mig-29. I just bought your old one from the guy who I assume bought it from you. Looks like quite the complicated mod.
Old 02-20-2017, 06:27 PM
  #631
gustavo Campana
dears ,
i maked all missiles pods for this mig. 3d printed, perfect scale,
anyone needs... let me know
gustavo
Old 03-18-2017, 07:57 AM
  #632
DornierJet
My Feedback: (91)
I see by reading this thread that the recommended cg for the mig-29 is nose heavy. So anywhere from the fwd wing spar to fwd fuse brace will work fine I'm assuming. What set up do you guys feel works best in regards to control surfaces. Ailerons only or ailerons with tailerons? I could not find any information on control throws either.
Old 03-18-2017, 09:04 AM
  #633
Edgar Perez
My Feedback: (13)
See good CG in photo.
Aileron only worked great for me.
Name:	Balance Point.jpg
Old 03-18-2017, 09:18 AM
  #634
DornierJet
My Feedback: (91)
Great! Thank you for the reply. Will make cg change. As of right now it's very nose heavy.
Old 03-18-2017, 09:39 AM
  #635
EUROSPORT JET IRELAND
I had ailerons only, and worked perfectly, I found with the tanks so far ahead of the CG, as the tanks emptied I had to feed in down trim. did not use gyros, probably would have helped if I did
