Comp arf Eurosport Evolution as a first jet / trainer
NM
I have a chance to buy a Comp arf Eurosport Evolution. I'm wondering what those who would know feel about it for a first jet/ trainer. I'm interested in knowing does it slow down easily? How are its slow flight characteristics? At our field we are unable to make long flat approaches so these things are important to me. Also any other noteworthy strengths and weakness that are known. I do have an experienced jet pilot that is willing to help me but he has no experience with the Eurosport Evolution. Any thoughts on this would be appreciated.
Luckyflyer
Luckyflyer
My Feedback: (23)
RE: Comp arf Eurosport Evolution as a first jet / trainer
The Eurosport is easily one of the best flying jets i'd have the priviledge of flying. Its slow flying characteristics are phenomenal. The field i fly at is a 1000' grass strip that does not allow for long flat approach's. I have to approach over 50' high tree's at both ends of the field and when you get the airplane in a nose high attitude and fly it down with power, you can land in Very short distance. I would have no problem at all recommending it as a first jet. To get it to slow down you just have to pull the power back and get the nose up and she'll fly along at just over a walking pace. Flying this airplane slow is one of my favorite things to do b/c it does it so well.
My Feedback: (49)
After spending the previous 5 years flying 40% gas IMAC aircraft, the original Eurosport was my first turbine jet. I don't think I could have made a better choice. The Delta wing is very forgiving and as Thomas already mentioned can come in at a very slow speed. When I upgraded to a Tam Hornet, I simply weighed down my Eurosport with extra weight to simulate the feel of the draggier F-18 before moving up. The Euro handled the weight easily & prepared me for power-on landings
Best of luck on your first flights, you'll love it! This Swiss was my second Euro. The first one ended shortly after the inverted photo you see here. It had over 300 flights and this was a repaint over of the original yellow ARF scheme.
David S
David S
My Feedback: (23)
I've got an older Ram 1000 in mine (28lbs of thrust) and honestly it has plenty of push and the verticals are plenty tall enough. So 28lbs would be the least amount i'd want to fly with one. Also trailing link struts are an absolute must! The first one i had, had the original gear that was recommended from C-arf w/ the straight struts and taxing down the runway you could hear how much beating the airframe was taking (and our runway is generally smooth). With the trailing links, everything is just over-all better and the airframe isn't taking as much wear and tear on it.
My Feedback: (23)
ORIGINAL: highhorse
you want at least 35 lbs if flying from grass on hot days if my bud's euro is any indication
Elevation here is 1238' and summer temps reach over 90*. My old ram 1000 does fine at pushing it off grass. granted it does take an additional 100-200' or so, but it does fine imo. I wouldn't want anything less though.
NM
One last question, what would the max straight and level speed be with a 36 lbs turbine?
Luckyflyer
Luckyflyer
ORIGINAL: luckyflyer
Luckyflyer
Luckyflyer
Be wary of guestimates, as they often are way off.
No,no no......I flew my basic Eurofighter at 4000 ft elevation on a grass strip with a standard P120. If it weighs between 22- 26 lbs dry that is all the thrust you will need. I have build three of them over the years with the final one being a fully scaled out version weighing 34 lbs dry.
d.w.
d.w.
ORIGINAL: Helijet
d.w.
d.w.
Luckyflyer
Luckyflyer
Measured with a Stalker Pro radar.
If thats the highest for mine, I don't know, it was just a casual measurement by one of the guys at a meeting
(My Elan went 313 Km/h )
I have measured mine with an Eagle tree ASI sensor and Seagull down link. With a Merlin 160 I was getting circa 160mph most days, and qround 170mph on a cold damp day.
min airspeed was about 35mph indicated, but I am not sure that at the high AOA that this latter reading is true. Actually it seemed much slower!
I have measured mine with an Eagle tree ASI sensor and Seagull down link. With a Merlin 160 I was getting circa 160mph most days, and around 170mph on a cold damp day.
IL
I had a Rhino in mine,flew it off of grass.I would not want anything less than the Rhino.Speed from gps in Weatronics reciever showed top speed of 165 .Very easy to fly.At times the delta wing was hard for me to see,which in the end was the cause of its demise.I replaced it with a Kingcat , but still mis the Eurosport and hope to replace it if I can find the time to put another one together.I enjoyed flying it more than I do the Kingcat.
My Feedback: (18)
OK
I have the Eagle Tree telemetry on My Euro powered by the AMT Pegasus HP (37lbs) and we have seen 180 mph passes.. Thats about all she will do..
FL
hello david i have been flying turbines for about a year and a half now. i am flying a boomer elan with a new p80se and am having a ball. i am looking to get a eurosport as a next jet. i am considering a jetcat 120 sx which is 30lbs thrust. the landing with the euro looks very slow. how would you compare the two.. also the rollout with this plane is it pretty short? just want to make sure i am making a good choice. thanks pat rose
My Feedback: (23)
ORIGINAL: ricardinho
The roll-out is dependent on your touch-down speed. You can land it with a bit of speed and stop in 500+ feet. Or you can really drag it in and stop in 150'. I can routinely get the thing on the ground and stopped with moderate braking on a grass field in less than 200 feet.
