CARF CT-114 Tutor 2.6m Build thread
#726
RE: CARF CT-114 Tutor 2.6m Build thread
Ralle sent out free ones to all purchasers there is also one in the manual you can copy I did and it wasn't to bad but I'm gonna put in the new one from Ralle
#728
My Feedback: (39)
Shaz,
I was looking for some detail images the other day and found these:
http://www.primeportal.net/hangar/da...tutor_cockpit/
http://www.primeportal.net/hangar/lu...tor_walk_2.htm
There are some pretty good shots of the dash in there.
PaulD
PaulD
#730
I'll try in a bit shaz I've been on call this weekend and been a bit busy if not tonight I'll try and get to you tomorrow
Kevin
Kevin
#732
I have noticed 3/32 play in my right elevator. The play is not coming from play in the servo or linkage.
It appears to be coming from the wire in the hinge in the inboard side. The wire might be slightly undersized for the hole in the hinge.
It does concern me somewhat, so I am asking those flying the Tutor if you are seeing the same situation and if so how much movement are you getting.
I do not have many flights on my Tutor only 13 so I don't believe it is a wear problem at this point.
Thanks for checking.
Stan
Stan
#733
Stan
So its got worse?
If you take the elevator off and thread the wire through the hinge blades on the tailplane, is there free movement of the rod? If so you could bush with plastic tube. Like I said before I've not seen this much play on any of ours.
Dave
So its got worse?
Dave
#734
ORIGINAL: Dave Wilshere
Stan
So its got worse?
Dave
Stan
So its got worse?
Dave
No it is still the same. Only 13 flights so far.
I am going to have to fix it I realize that.
My personal feeling is that 3/32 might be pushing the limit.
Curious if this is a problem with some of the other Tutors out there.
As always thanks for your quick response.
Stan
#736
Rob
I think more the better, but 20mm take off and 70mm Landing measured at root TE is my manual figures.
Dave
Dave
#738
What size servo arms are needed for the flaps, ailerons, rudder, and elevator? I don't have the plane with me to check and I need to order aluminum arms.
Thanks!
Thanks!
#740
a rare sight
Alan Blores #1
Kevin Forsyths #2
Paul Dries #3
Dean Wichmanns #4
we had a great time this weekend and Paul and I both flew with Dean and did some formation stuff
it was a blast
Again Dave thanks for helping make our dream come true
Alan Blores #1
Kevin Forsyths #2
Paul Dries #3
Dean Wichmanns #4
it was a blast
#747
I got them from Ron dileo @premier pilots you need to lop off abt an inch from abdomen but they look great.
Use the carf helmet and some foam to fit
Kevin
Kevin
