ECU Issue
CA
Hello.
Does anyone had seen this issue before. I have setup the Xicoy ECU AU-605 Auto Start. Everything was connected and programmed
as the online manual says. Upon power on to the ECU, the pump would just start to run at full speed and won't stop.
Any help would be much appreciated. Thank you all.
CA
Hello.
I had follow the harness layout label on the ECU very carefully. The ECU seems to function correctly on everything else.
Just the fuel pump start to run as soon as power is turn on. I have no idea why.
CA
Hello all.
Xicoy had used two wire for pump and battery that are so close in color. It was why I couldn't identify whether it was pink, or orange, since put them
all in a bundle, its really difficult to distinguish between them two. I switch them around, and the problem is now fixed. I thank you all for your help.
Neil.
Neil.
