 RC jet maintance >
RC jet maintance
RC jet maintance
Old 02-23-2010 | 05:10 PM
pquispea_m5's Avatar
Default RC jet maintance
Hi there,
i wonder how much the maintance of a rc jet propulsed by turbine cost, 20kg of thrust for example?
greets,
Pablo
Old 02-23-2010 | 05:23 PM
Default RE: RC jet maintance
Pablo, it depends on how often you crash....
Jack
Old 02-23-2010 | 08:12 PM
Guillermo Ibanez's Avatar
ORIGINAL: Jack Diaz
Jack
Ha ha ha ha...Come on Jack...... Be serious......
<br type="_moz" />
Old 02-23-2010 | 08:15 PM
Jeffpro's Avatar
A few hundred bucks at recommended service intervals, generally every 25 hours of run-time. More if you mistreat the turbine.
Old 02-23-2010 | 09:57 PM
ORIGINAL: Jeffpro
the maintance time you mention is for the turbine isn't it? and what about servos and valves how often it should be replaced or checked? to avoid failures in fligth as Jack said. some of you have a plan maintance for a toy of $15-20000?
greets,
Pablo
Old 02-23-2010 | 10:37 PM
erbroens's Avatar
Just inspect and repair as necessary. There is no data available on the durability on any hobby related component so maintenance planning is not possible.
So far (fortunately) for me the biggest expense after initial purchase is fuel.. ($8 a flight)
Old 02-24-2010 | 08:24 AM
ORIGINAL: erbroens
US $ 1,58 a flight (2 liters buned each flight with a Jet Cat P-80 5 minutes flight duration).
Maybe you need to replace tires, check for loosen screws, check for air leaks, etc. But the major cost is sending the turbine to the factory each 25 hours of use and the fuel you use.
But as Enrique and Jack said, if there are no crashes, scratches, broken gear during landing, etc., maintenance costs are negilctible.
<br type="_moz" />
Old 02-24-2010 | 09:29 AM
erbroens's Avatar
Guillermo, the turbine oil is included in this cost?
Old 02-24-2010 | 09:34 AM
ORIGINAL: erbroens
Nope. Sorry. It is another USD $ 1,58
Total per flight: USD $ 3,16
<br type="_moz" />
Old 02-24-2010 | 11:37 AM
erbroens's Avatar
Even so is cheap. Everytime I buy the fuel cans I think I rather start flying gliders and spend the money dinning a churrasco.. That could be a wiser maintenance plan.
Old 02-24-2010 | 01:28 PM
Stobe777's Avatar
I pay maintenance fees gladly as then it means I found 25 hours of flying time from nowhere... So far the equipment has more hours to deliver than I have to receive.
TP.
Old 02-24-2010 | 02:04 PM
ORIGINAL: erbroens
Yeap.....
One gallon of Jet A1 at the airport is USD $ 3.oo. Of course if you include the car expenses for traveling to the airport to pick it up, it cost USD $ 3.oo more per 5 galons can plus the shipping cost for 4 oil cans USD $ 5.00, total cost would be up to USD $ 4,72
P.S.: If I would have read this post before lunch, probably I would have beat my computer screen.... This churrasco seems to be very delightful.........
Old 02-24-2010 | 02:09 PM
erbroens's Avatar
You forgot to include the tip for the jetA1 fuel truck operator..
Old 02-24-2010 | 02:14 PM
ORIGINAL: erbroens
OK,, OK,,,USD $ 5,22......We are closer......
<br type="_moz" />
Old 02-24-2010 | 02:17 PM
alasdair's Avatar
There are hidden maintenance costs to dining regularly at a Churrasco too
Like replacing all my pants with a bigger size!!
Old 02-24-2010 | 02:34 PM
erbroens's Avatar
Maybe this counts as upgrading costs ?
Old 02-24-2010 | 02:58 PM
olnico's Avatar
It aslo pretty much depend on what kind of plane you fly.
For example, a Fly Eagle Jets model will cost you some money in landing gear components/pistons change at a regular interval. Also the time spent to keep the thing in flying state is money...
Anyway the maintenance on our models is "on condition".
You'll get to identify the weak components and inspect them at the proper interval...
Old 02-24-2010 | 05:32 PM
cmjets's Avatar
Hello:
I think if you spend the money in a good Landing gear, servos, valves, turbine... you will need less maintance...
... And if not hit the jet each landing.
Saludos desde EspaƱa.
Carlos.
________________________________
http://cmjets.blogspot.com/
