Ziroli Panther
My Feedback: (32)
RE: Ziroli Panther
ORIGINAL: smchale
Kirk,
Wow, you've come full circle....seems like forever ago you built a beautiful aeronaut panther. Can't wait to see how this one shapes up. I've always liked the panter and thought ziroli had the size bang on.
Did you laminate the ply with CF cloth in a press, or did you use something like the dragon-plate pre-made sheets on a sheet of ply before cutting? Looks nice.
Kirk,
I laminated carbon cloth onto the ply formers with West Systems laminating epoxy. I brushed the epoxy on and scraped off the excess like you do when glassing an airframe. Then I laid a plastic sheet over the formers and put weight on top.
Kirk
My Feedback: (32)
RE: Ziroli Panther
ORIGINAL: scalebirdman
Kirk,
Where did you order your fan system from?
Kirk,
My Feedback: (67)
RE: Ziroli Panther
ORIGINAL: k_sonn
I received the power system for the Panther today.
Kirk
Kirk
Sweet!! That ESC does looks slightly smaller and lighter than the one that came with my DS-94. Positive improvement. It looks like your controller doesn't have the anti-sparking lead, rather two servo leads?
How do you like the fan on first inspection? Pics don't do it justice...
#31
My Feedback: (32)
RE: Ziroli Panther
ORIGINAL: smchale
The second, shorter servo lead is labeld "Programming Box." The 160A controller doesn't have the anit-spark wire. I'm not sure but the anti-spark may be built into the controller. The controller manual is in German so I can'tverify that yet. I will place a call to Peter to see if he has an English version of the controller manual. If he doesn't, I'llemail Ralf to see if he can translate it to English.
On first inspection, the quality is outstanding. It's on par with the quality of the BVMEVF but I won't compare the fans beyond that because they are designed for two different goals, meaning the BVMEVF is designed for high dynamic thrust and the DS HST fans are designed for high static thrust.
Kirk
#37
My Feedback: (32)
RE: Ziroli Panther
ORIGINAL: Redline7000
For the ignorant and the layman. Whats the difference between High Dynamic Thrust and High Static Thrust?
If there are any engineers orout there that see any flaws, please let us know.
Kirk
#39
My Feedback: (32)
RE: Ziroli Panther
ORIGINAL: Xairflyer
oh no you are not putting a hairdryer in that fantastic fuselage, throw it over the hedge and buy a turbine
#40
My Feedback: (32)
RE: Ziroli Panther
It'll be the coolest sounding hairdryer/leaf blower in the nieghborhood Here's an example of what the DSHST fan sounds like in a 23 pound F-20:
http://www.youtube.com/watch?v=g5GoB...layer_embedded
#43
My Feedback: (32)
RE: Ziroli Panther
Now that I have finished other projects I was working on, I can begin my winter build. The fuse formers were cut out earlier, see the beginning of this thread. So, to begin the build I started out bydry fitting the formers in the fuse to check for fit and noticed a potentialiy weak area, especially with the light layup of the glass. There are 2 formers just in front of the cockpit for the nose gear and there are 2 formers at the mid wing section of the fuse for the main gear. There is nothing in between these formers. I touched the section of glass between the formers and there was good amount of flexing. i was intending to lay some carbon fiber in the area of the gear doors so they would be nice and stiff when I cut them out so I killed two birds with one shot and laid carbon fiber from the front of the fuse to the trailing edge of the wing. This added 8 ounces of weight and stiffened the fuse up nicely.
Kirk
Kirk
#44
My Feedback: (32)
RE: Ziroli Panther
Next, I started construction of the horizontal stab. I laid the plans on the building board and pinned the ribs in place, added the spars, sanded and sheeted. I deviated from the plans by adding 1/2 inch balsa blocks for hinging because I will use Robart pin hinges instead of the flat nylon hinges shown on the plans.
Kirk
#46
My Feedback: (22)
RE: Ziroli Panther
cool project Kirk
I'll be following along. One of the clubs I fly at the president has a Ziroli Panther I believe with a P-80 in it... flies really nice.
He has had some tracking problems with the steering but that may be more his setup than anything. I know he added a gyro to help keep it straight on take off.
Back in the day I watched two of these at a meet fly on os 91 dynamax power and they flew well... they struggled on take off but once on step they flew real nice.
Your going to have like three times the power those guys had
keep up the good work
I'm about done with my move and have been setting up my shop so I can get back to building... it been 2 months since I've touched a plane []
later
Ron
later
Ron
#48
My Feedback: (32)
RE: Ziroli Panther
The plans show theelevators as having oneservo with a U-shaped rod connecting the left and right elevator. I perfer to have a servo per elevator and the JR DS3421MG just fit in the bay between the 2nd and 3rd ribs. I laid carbon fiber in the bay to strengthen the skin and let it set up over night (1st Photo). Then I made up some hardwood servo mounting blocks. Just before drilling them I glued .010 G10 to each side. This prevents the blocks from splitting when drilling and/or attaching the servos (Photos 2).Once the carbon was dry, the servos were attached to the mounting blocks and were glued in place with Hysol.
#50
My Feedback: (32)
RE: Ziroli Panther
I started sheeting the bottom of the horizontal stab when I realized I didn't have enough 1/16th to finish it. I had just enough to complete the stab. I'll sheet the elevators after I get some more sheeting. I'm also waiting on hysol glue to arrive so I can glue the formers in the fuse. It should arrive tomorrow. In the meantime, I framed the right wing. It is ready for sanding and sheeting.
Kirk
