 Thin Wing Servos >
Thin Wing Servos
Thin Wing Servos
Old 04-21-2010 | 06:47 AM
Default Thin Wing Servos
Firstly, does anyone know if the JR DS171 in the UK is the same as the JR368?
If so, how are people getting on with these servos? Any issues? Do they live up to their pretty impressive specs?
The Hitec 125, 5125 are not allowed in my club on flight surfaces due to previous reports and experience of gears stripping. Am I correct in thinking that the 171/368 gears are stronger? Any reports of stripping gears with these servos?
I am looking at putting them on elevators (and possibly ailerons) of Wren 44 powered Comp ARF Spark.
Old 04-21-2010 | 07:03 AM
Default RE: Thin Wing Servos
Slick
The 171 is a new servo from JR, I haven't used any yet but have not heard of any bad reports. This is a wing servo with multi mounting options.
The 368 has been superseded by the 362.
If you go to MacGregor's site they have dimensions and specs.
http://www.macgregor.co.uk/jrpropo/mini.htm
I cant see you having a problem using them on a Spark. I had 161's on the elevators on a 44 powered Savex L-39 which is still going strong 5 years on!
Steve
Old 04-21-2010 | 07:08 AM
Oops, number faff. This numbering system is a nightmare
I meant to ask if 171 was the same as 378 (not 368)!
Old 04-21-2010 | 07:45 AM
Slick
The 378 is a US number for what appears to be the 171 (as is know by the rest of the world).
Hope this helps
Steve
Old 04-21-2010 | 11:22 AM
I have DS 161's in both my EDF Sparks (inc the 220+ version) and 3301's in the P60 turbine version. I'm not a big 3301 fan, but they have been fine for 2 years...
Dave
Old 04-22-2010 | 02:18 PM
Anyone using the 378s?
Old 01-06-2012 | 12:31 PM
ModellbauUK's Avatar
I am fitting DS171 to the elevators of the MBA Sabre. Any clues on how these are mounted?
Old 01-06-2012 | 12:34 PM
You can snap off the lugs on one side and screw the servo onto a plate/bearer. Be careful though, they break off very easily[X(].
Old 01-06-2012 | 01:02 PM
Greg Wright's Avatar
Hi siclick33, I have been using the 378HV's in my BVM F-100 on the leading edge slats and they have been holding up just fine. The hole plane is set-up with HV servo's and i have been using a 5000 mah lipo with no regulators and no problems at all.
Old 01-06-2012 | 01:12 PM
ORIGINAL: siclick33
i've got them on the rudders of my F-15, they work great. the side mount screws make installation a breeze.
Old 01-06-2012 | 01:37 PM
marc s's Avatar
I would suggest the MKS6125 the best centering thin wing servo I have come across yet... slightly cheaper than the DS171 too, more powerful and has an optional mounting plate and tiny aluminium horns.
[link]http://www.mks-servo.co.uk/mks-wing-servo-ds6125-mini-26-p.asp[/link]
marcs
