 Mibi A-10 GAU-8 >
Mibi A-10 GAU-8
Mibi A-10 GAU-8
Old 05-04-2010 | 10:00 AM
My Feedback: (39)
Default Mibi A-10 GAU-8
After 6 months of tinkering...
Blows powder thru the front barrel, using a NOS solenoid, high pressure lines and a servo operated cam to trigger the micro-switch. Pressure tank is buried in the center section, and is constructed from two thermos bottle inner liners welded together. Holds 300 psi easily. Filled from a paint ball Co2 bottle.
I am currently using flour as powder, but need some suggestions for a dark colored substance. I've thought about black pepper...but that could lead to a sneezing problem.
ID:	1430681   Click image for larger version
ID:	1430682   Click image for larger version
ID:	1430683   Click image for larger version
Old 05-04-2010 | 10:07 AM
Default RE: Mibi A-10 GAU-8
nice work any video of it in action ?
Old 05-04-2010 | 10:11 AM
My Feedback: (39)
No video yet. The pic shows a small bit being shot out. Actually the tank is empty. And being indoors, I didn't want to shoot a full tank. I'll get it assembled outside hopefully this weekend. Trying to take a still pic with a cheap digital camera is difficult, as it fires three times per throw of the slider switch.
Old 05-04-2010 | 10:13 AM
LGM Graphix's Avatar
My Feedback: (22)
ORIGINAL: Wren Turbines USA
How about grinding up some black chalk pastel's. Would give the added benefit of realistic powder streaking on the airplane too! :P
You can by dry graphite lubricant as well, might work for a puff of black.
Old 05-04-2010 | 10:20 AM
My Feedback: (57)
VERY cool Ron!!
Video of that thing in action would be great.
Old 05-04-2010 | 10:53 AM
My Feedback: (9)
Powered Thermo ink for the old copier's. I use it to streak models. it will pretty much wipe off unless you heat it, with a hear gun. than it is permanent.
Old 05-04-2010 | 10:59 AM
That is one of the coolest ideas I've ever seen. But I think I would be worried about the graphite or chalk or whatever getting sucked into your turbine. I can't imagine it's gonna be too good on the bearings.
Old 05-04-2010 | 12:44 PM
My Feedback: (101)
whats the sound like?
Old 05-04-2010 | 01:08 PM
My Feedback: (39)
No sound.........just tat-tat-tat
Old 05-04-2010 | 01:36 PM
My Feedback: (15)
Looks great Ron!
Any worries about all that powder going through the turbines?
Hope to see this working at Winamac!
Dave
Old 05-04-2010 | 01:51 PM
My Feedback: (39)
The issue of the turbines ingesting the powder has been discussed, slept on, thought about...even drank a few beers trying to resolve the question. The protective screens on the Wren motors won't protect from the finer ground (ie: flour)...but I thought maybe a rough ground pepper may be heavy enough to fall below the engine level...with the hopper full of flour...the stuff REALLY comes out!! Any constructive ideas are welcome...as I would love to offer this idea to all the Hog owners.
I even thought about putting a smoke bomb in the hopper????
Only time and trial will tell!!
Old 05-04-2010 | 04:11 PM
My Feedback: (15)
HI Ron,
I only mention it as I recall in my reading that the full scale A10 during testing had episodes of engine stall during longer gun runs.
What I read was that this was due to the exhaust from the rounds being ingested (not an airflow issue).
SO I just thought that if the gun exhaust caused an issue in the full scale that it could be an issue. I dont want to be a kill joy.
I finally have mine back together with Details 4 Scale lights, Jet Tech tanks and a fresh new smile painted on the nose.
Dave
Old 05-04-2010 | 04:17 PM
invertmast's Avatar
My Feedback: (23)
I dont think the gun exhaust would be an issue, as the airflow from the bottom of the fuselage spilling over the sides infront of the wing will follow the upper contour of the wing airfoil and fall below the engine pods... atleasts thats what i'm thinking
Old 05-04-2010 | 05:01 PM
My Feedback: (15)
interesting reading..http://en.wikipedia.org/wiki/GAU-8_Avenger
Old 05-04-2010 | 05:07 PM
My Feedback: (15)
maybe this one will work? http://en.wikipedia.org/w/index.php?...r&id=359044116
Old 05-04-2010 | 05:49 PM
starwoes's Avatar
i thot the stall wasn't from the engine injesting the spent powder fumes but rather, an actual aerodynamic stall due to the powerful gun's recoil slowing down the aircraft's airspeed.....heard the airplane loses a few knots if u lay on the gun. could be wrong however.
Old 05-04-2010 | 06:04 PM
My Feedback: (15)
an excerpt
The A-10 engines were initially susceptible to flameout when subjected to gases generated in the firing of the gun. When the GAU-8 is being fired, the smoke from the gun can make the engines stop, and this did occur during initial flight testing.[2] Gun exhaust is essentially oxygen-free, and is certainly capable of causing flame-outs of gas turbines. The A-10 engines have a self sustaining combustion section. When the gun is fired the igniters come on to ensure no flame out occurs.[13]
Dave
Old 05-04-2010 | 06:23 PM
starwoes's Avatar
heard wrong then. good info...always thot of that gun as an overgrown monster to stall out a whole aircraft.
Old 05-04-2010 | 07:20 PM
CraigG's Avatar
My Feedback: (40)
Very cool. Sounds similar to the system on a crop duster a guy used to win Top Gun a year or so ago.
Not sure why you want a dark colored powder. The smoke trail from the real one is mostly white.
Craig
Old 05-05-2010 | 12:21 AM
-JC-'s Avatar
My Feedback: (26)
Pretty cool stuff Ron.
Have you seen this one?
http://www.youtube.com/watch?v=xcuk8...=youtube_gdata
Old 05-05-2010 | 04:01 AM
My Feedback: (45)
Ron,
At any art store you can get graphite charcoal powder, thin enough to mix wit powder and or flour.
Great job.
Joe
Old 05-05-2010 | 07:26 AM
geh3's Avatar
My Feedback: (84)
Hey RON,My vote is for the <span class="watch-expander-head-content"><font size="4">
</font></span><div id="watch-main"><div id="watch-panel"><div id="watch-info" class="yt-rounded expanded"><div id="watch-views" class="watch-expander yt-uix-expander yt-uix-expander-collapsed" data-expander-action="yt.www.watch.watch5.handleToggleStats"><di v class="watch-expander-body yt-uix-expander-body"><span class="watch-expander-head-content"><font color="#0033cc">maxotronic</font> System!!! <span>Electronic Machine gun to be used in RC-Helicopters, aircrafts or tanks</span>
This will give you the most realism.....
GO FOr It...</span></div></div><div id="watch-description" class="watch-expander yt-uix-expander yt-uix-expander-animated" data-expander-action="yt.www.watch.watch5.handleToggleDescriptio n"><div class="watch-expander-body yt-uix-expander-body" style="height: 129px"><div id="watch-description-body"></div></div></div></div></div></div>
Old 05-05-2010 | 08:21 AM
CraigG's Avatar
My Feedback: (40)
Unfortunately the real GAU-8 has more of a loud "growl" than a rat-a-tat-tat sound. Listen to this:
http://www.youtube.com/watch?v=sALiuWg_I1k
Just wish somebody made a small and loud enough speaker to install inside the fuselage.
Craig
Old 05-05-2010 | 11:56 AM
My Feedback: (86)
Craig,
I have iFart on my iPhone and I think I know where they get the "greesy enchalada" one from
WOW!
Rex
Old 05-05-2010 | 04:18 PM
myork's Avatar
Very cool! It would be sweet if you could incorporate something like a progressive controller for nitrous systems. Instead of just opening the solenoid it will actually pulse the solenoid for whatever rate you program it vs the engines current RPM. Now I know there is no way you could cram a progressive controller in the a-10, but there has to be a DIY circuit out there that will pulse 12 volts to the solenoid. I'll do some digging around on the net and see if I can find one that will work. Most circuits like that use a 555 timer for the clock signal and a potentiometer to adjusted the rate of the pulse aka how fast it will fire.
EDIT: Found one that could work. Basically leave your servo operated switch in, but you don't want the cam function. You will just need off and on. Here is the diagram and a parts list
http://www.electronic-circuits-diagr...rsimages/1.gif
Parts list:
1 555 timer
1 1k ohm resistor
1 1M ohm potentiometer
2 0.01uF Capacitors
All of this should be available at your local radio shack
