MANEUVERING TANK
My Feedback: (14)
MANEUVERING TANK
I recently started adding what I call a maneuvering tank to all of my jets that have molded conformal fuel tanks. Because of the unusual shape and other restrictions of some of these tanks the fuel pickups are placed in less than optimal locations. The clunks cannot be easily made to follow the fuel through heavy maneuvering. This causes air buildup in the UAT followed by a flame out if you continue maneuvering for too long. By placing a small (8-20oz) standard polypropylene tank with a good clunk installation directly ahead of the UAT you increase its air handling capacity. Good fuel delivery can be maintained throughout the entire flight. I think anyone flying a jet with a less than optimal fuel pickup location should consider installing a maneuvering tank if they’re doing anything more than flying the pattern. Just something to consider.
RE: MANEUVERING TANK
Hi Wayne,
When you say, ahead of the UAT, Do you mean before it, between the main tanks and the UAT ???
Maybe some pics would be helpfull...
Cheers Jeremy.
Cheers Jeremy.
My Feedback: (14)
ORIGINAL: Sonicwings
Hi Wayne,
Cheers Jeremy.
Hi Wayne,
Cheers Jeremy.
Is it the same thing as a header tank?
I was planning on putting in a small 12-14oz header tank to supplement the conformal tanks in my SM F16 so was just wondering if they're the same thing? noob here... forgive me
Rob
Rob
Ahead of my 4oz header tanks I now also run a 2oz pre-header tank and am thinking about a 1oz pre-pre-header-pre UAT tank
Hmmm, I had a EuroSport which I put about 50 flights on with a coke bottle for a tank and nothing else. Never failed on me. I do now run UATs but there has to come a point where things are just getting too involved???
Mark
Mark
ORIGINAL: schroedm
Mark
Mark
I have a 12 ounce "header" or "Hopper" tank in one of my jets for this reason as well as to add a few minutes of reserve fuel. It's a basic square tank made by DuBro with the fittings for Kerosene. The main tank is a relatively flat and wide tank making it a bear to get all the fuel out without sloshing and sipping air every once in a while. I always land with main tanks and saddle tanks completely dry and still plenty of fuel in the "Header, Hopper, Maneuvering" tank or whatever we call it! The UAT is completely full, no air at all. Not every plane will need this of course, some sport jets are blessed with just one high volume main tank with perfect clunk placement!
