Total lock out on JR12 2.4Ghz
#326
RE: Total lock out on JR12 2.4Ghz
ORIGINAL: VF84sluggo
Just when I was about to pull the trigger and switch to Futaba, I find a discussion on another 'giants' flying forum where a guy's q500 race plane lawn-darted. He was using a 12FG. It can be found on that Giants Flying forum under ''Futaba 12fg problem and crash.''
#328
My Feedback: (9)
Dang I just saw the add for that and thought I was going to have it first!
ORIGINAL: Woketman
I am considering purchasing the new Unobtanium 18X-FG. 78.2 GHz reliability paired with a quantum computing reciever with Heisenberg servos driven by a small matter/anti-matter power cell (regulated to 105 volts).
Only the BEST!!!
Only the BEST!!!
#329
My Feedback: (84)
WI
So tell me again why I should use 2.4 when we have to share it with just about any device. I have switch back to 72 on my bigger planes, I have had no problems with the JR RX’s (using the FM and PCM) for over 20 years and will go back to using the 2.4 on smaller electric/foamies. I think we were forced into 2.4 by the park flyer market (Toy Airplane) and were told it is bullet proof when it looks like it is not. Not all of us fly toys. At least the 72 band had 50 channels that we did not share with too many other devices. I feel safer using the 72 band since I have no problems at all. It is hard to tell at this point which system has is better since we do not know how many systems are in use for each manufacture, it may be to new of a technology to clam bullet-proof. I am using Futaba and Spektrum and currently Futaba 0 hits, Spektrum 6 hits, 1 plane, and one landing gear. I am just going to sit back and see want comes out next. This reminds me when PCM came out we heard the same type of stories (lock out then crash) then magically everything started to work.
#330
My Feedback: (55)
ORIGINAL: FILE IFR
Futaba, JR, Scaretronics.... they ALL crashed a plane at one point or another. That being said, what brand of radio system would you consider buying now?? [&:]
I thought I'd settled on the 10CG, but I need more than one channel with servo-slow capability. So, I looked at the 12FG, even though that would stretch the budget. Then I discovered all this stuff about software update problems, uncommanded aileron movement with throttle movement, elevator problems, etc., with the 12FG. And $1400 for a 12Z...ygbsm!!!...would probably be a divorce issue, too.
So, I'm back with my trusty (so far) x9303 looking like the prettiest puppy in an ugly litter.
#331
My Feedback: (8)
ORIGINAL: Woketman
Only the BEST!!!
Only the BEST!!!
It still has problems with the matter/antimatter constrictor propagator.
The problem doesn't affect the flight of the model but whenever you input left aileron it fries one of your balls.
I've had my balls replaced 3 times but at least I come home with a jet every time.
#332
My Feedback: (7)
ORIGINAL: rjbob
I've been using the beta version.
ORIGINAL: Woketman
Only the BEST!!!
Only the BEST!!!
#333
My Feedback: (162)
Here's someone selling a 14mz for $1300... I used one for quite awhile, great radio!!
http://cgi.ebay.com/FUTABA-T14MZP-2-...item3cb0ea6336
#334
ORIGINAL: jonkoppisch
The 2 pictures in the ad appear to be each mode.
#336
The trouble with adjusting the knuter valve is it activates the cloaking device, I put it down to re-adjust the hyper alergnic drive and now I can't find it.
Mike
Mike
#338
I had another seven flawless flight`s with my turbine powered f-16 yesterday (about 100 to date) with my 12x. but every time i go to take off it`s at the back of my mind....will it be the last.
The issues that obviously do exist, although i dont beleive they are anything to do with low voltage or even the non channel hopping of the DSM2. We flew for many years on one channel/line of cummunication on 35/72mhz with no problem.
I was starting to lean towards poor fitting/bad connections of the remote RX` to the main reciever causing the lock out`s, but the orange light`s would flash to let you know this had happened.
I should maybe also say i`ve had a few hundred flight`s in total (all on 4.8v apart from the f-16) on the 12x with various RX`s with not even a hint of trouble.
The only model that has had high readings on the flight log including frame losses and even a couple of holds is my weston magnum, but noticed nothing when the model was actually flying.
john
john
#339
Had another 6 flights on my Rookie today but I must say with the problems people are having and freinds moving to Futaba every flight was a see what happens event but saying that I have not lost a plane to JR 2.4.
#340
My Feedback: (84)
WI
I think the problems are dependent on where you fly. If you think about it FASST is getting hit by the same RF interference as DSM2. We are sharing the channels with unknown sources and it depends where you fly. DMS2 may not do well under areas where heavy use of the 2.4 Spectrum from industrial use. Channel hopping is just never in on place long enough to get hit. DSM2 is stuck on 2 channels and is a fixed target. What I do not understand is, I thought the DSM2 (all 2.4 systems?) system had a MAC address or some sort of data string that identifies the TX and RX. If that is true how can it be hit? The RX should only act on data tha tmatches the TX signal. It should go into failsafe and I have yet to have a problem plane go to failsafe or even blink the lights.
#342
My Feedback: (29)
The DSM systems get hit because in an environment with heavy signals in all channels (or the two channels being used) all frames are lost, whereas on a FHSS system only the frames on those channel are lost, if you think about it, since all FHSS transmitters turned on at a time are not synched to each other, each is using alternate channels at a time, this happens so fast that the information available, even with the losses, is enough to keep the link. All 2.4 systems use a code that's specific for each transmitter, in DSSS if the two channels used are blanked out or "overwelmed" by many signals, the code just does not help because the signal may not reach the receiver for the same reasons above. The code allows the receiver to respond to the transmitter it is bound to, but the channel has to be open for a long enough period of time for the frames to pass. In FHSS, open channels will be available almost always.
#343
My Feedback: (84)
WI
Great explanation “Ruizmiton”…….. I am going to stick to my conclusion that DSM2 is good for my small electrics (Bind-n-Fly stuff) and use the FASST system for my larger planes.
#344
My Feedback: (55)
ORIGINAL: 3dsky
However, I think we all know that regardless of the manufacturer, nothing man-made is 100% fool-proof. I think all we're looking for is the 2.4 system that makes that risk as minimal as possible. It's crazy, I have no reason to be loyal to JR/Spektrum, but I feel odd as I realize I'll most likely have a Futaba FASST setup in my L-39 before I maiden it in the next week or so.
#345
My Feedback: (29)
Had this exact discussion today at the field, and it seems this is becoming the concensus, even from some long time die hard JR/Spek DSM2 folks. While I don't want to lose ANY plane due to bad 2.4 technology, even my PZ T-28 (a dumb-thumb is my problem and I can live with that), I sure don't want it to be the cause of losing a big $$$ turbine.
ORIGINAL: 3dsky
VF:
If you have the same situation like me (Hate Futaba programming/Hate Spektrum system) your best compromise is the JR/FASST module, that's what I did, if you want to retain JR's programming capabilities, the minimum you need to get from Futaba in a Radio is the 12FG, any radio below it is not camparable to a 9303, even less a 11X or a 12X.
Yet if you think a 10C can do what you need, I have a 10C at a very attractive price in the classifieds
#346
[youtube]http://www.youtube.com/watch?v=_6jw8o0y61I&feature=related[/youtube]
#347
My Feedback: (55)
ORIGINAL: Ruizmilton
So, I look at the 12FG, but a die-hard Futaba guy said don't do it...bad TX. Folks have had problems with it (couldn't help but respond, What??!!, thought Futaba was the Holy Grail). So, next up is the $1400+ 12Z...say baby! Big $$$$. Not gonna happen.
And here I end up back with an x9303, AR9100 with 4 remote rx's, and my fingers crossed that I'm not next to have DSM2 bite.
#348
My Feedback: (22)
I just maiden'd my JMP Firebird this weekend with a JR12X and 1221 receiver, not a glitch, rock solid. I also put multiple flights on my Raptor again this weekend, all at 220+mph with an AR9000 receiver with one satellite receiver.
I have no issues with JR/Spektrum, if you set it up correctly, make sure the radio is on and transmitting before you turn on the airplane, and basically, follow common sense, they work perfectly. At the Princeton rally this weekend the radio's were significantly more JR than Futaba, the only unexplained crash this weekend was a Habu with a Futaba FASST system (not saying it was the Futaba radio though, we have no idea what happened, control was simply lost).
I crashed my Habu as well on Spektrum, but that was a lost connection between the brain and the thumbs, nothing to do with the radio LOL
#349
My Feedback: (29)
Spektrum's system will work OK under a specific set of conditions, some will never experience any issues, but in simple terms, there are better systems, there is no need to risk a high dollar plane with lesser technology, most of the parameters that will cause a Spektrum system to fail, away from the installation, are beyond the user's ccontrol, the other systems just eliminate some these issues. Just because it works for some does not mean it's subjected to the same issues as others, since they are different technologies, they cannot be compared. DSSS requires at least one of the 2 channels to be clean all the time, FHSS just require one channel open out of 80 a few times a second.
Are you willing to take the risk even though you know there are more robust RF systems just because you prefer a brand?
Believe me, I'm a hardcore JR guy, but under no circumstances will fly a jet on the spektrum system.
#350
