Converting Byron F-18 to EDF-Advice needed
My Feedback: (27)
QC, CANADA
Hello
I have a Byron F-18 that I would like to convert to EDF.
I'm sure that someone tried this before!So what is the optimal set up?
I'm looking for a single engine system(like the original IC).
Target weight is around 18 pounds.
Any imput iis appreciated!
Best regards
Spike
Best regards
Spike
RE: Converting Byron F-18 to EDF-Advice needed
Tam Jets is coming out with a 120mm fan that should be right up your alley
if you go to www.rcgroups.com they have a lot of info on EDF's and different
motor and fan combo's. You have to be able to get passed the hyped up
motor and fans though and get some actual test data from real customers.
Some of the manufacturers are like badgers they claim their product is so great
but then they don't have anything in stock at events. Tam has been the best at posting
videos and working long hours to get it right. Just my opinion...
P. Richards aka SwatTeam
Try www.wemotech.com www.proedf.com I may be doing the same. To a BAe that is running an O.S. .91max DF.
Tuskegee
U.S.Army(ret.)
Tuskegee
U.S.Army(ret.)
As P.Richards said, This is all the info you need.
http://www.rcgroups.com/forums/showt...ighlight=byron
If you look at the EDF forum, there are lots of threads on 120mm fans (byron sized)
Also check out the XPS products. A lot of guys are having great success with their fans and packs.
dave
dave
My Feedback: (27)
QC, CANADA
ORIGINAL: ticketec
dave
dave
That's exactely what I'm looking for !
Thanks guys
OH
www.Ductedfans.com [link=http://ductedfans.com/Ducted_fan_impellers_EDF_units.html]EDF units [/link]EDF units from 140 to 2.5 mm as well as custom fans for whatever.
Morris
Morris
ORIGINAL: Ductedfann
Morris
Morris
My Feedback: (29)
Andy,
Byron did go out of business quite a while ago, but there is still a lot of Byron stuff floating around.
I am at work so I don't have access to any pics, but if memory serves the Byron was about the same size as a YA F-15 (85-86 inches long)
They did not offer scale gear for it (mains were straight struts)
The only one I ever saw fly was very underpowered with the Byron fan and OS.91.
OH
Hi Andy,
My post was about the OP's question. I only have a few posts I'm not so forum savy, the reply is automatic if you don't choose to whom you are addressing. I was addressing anyone about the TF 8000 being a drop-in replacement for a Byron fan.
On the page for the [link=http://www.ductedfans.com/Turbo_Fan_8000_Ductedfanscom.html]TF 8000[/link]TF 8000 it does say "What to do with TF 8000. The TF 8000 is a good fan replacement for Byron units".
Morris
Morris
BC, CANADA
The Byron F-18 is a large heavy jet. Even though the Byron e conversion is a good cheap fan (I have 2 of them) and they can put out more power than the OS91 glow setup, I would go with one of the Dynamax conversions.......one of them would give the '18 much more life.
