A123 users question
nope....the black wire is continiuos and not broken by the switch in most switches.....the white wire does nothing, it's a phantom wire....the problem occurs because most chargers on the market "sense" on the low, or negative ( - ) side.....since the negative wire is not broken with the switch, the chargers get confused and freak out.....
http://www.rcuniverse.com/forum/m_92...tm.htm#9249729
Makes no difference what kind of battery.....I am guessing u are using 2 seperate batterys to power the Tritons?
There is another thread with a bunch of info on this....I'll find it later and post it here...
My Feedback: (29)
TX
Using power supplies, could that be the difference? So, is it safe to say that if Ihad no problem with Lions that Ishouldn't with 123's? The other difference is Ihad a Batt Share between the switch and the rx.
Smitty, clarify please.....r u using 2 SEPERATE power supplies?
If it's the Smart Fly Batt Share, it won't isolate the common ground....I use them also...the Electro Dynamics batt backer will eliminate the common ground issue, but has too large a voltage drop for me.....
#32
ORIGINAL: furloughed ual
Nope...it's not ED....just checked with them.....I know the JR HD and the MPI HD switches do not....any other ones you've used that might be the one?
ORIGINAL: highhorse
Dude, i wish I remembered. Sorry. Check the electrodynamics folks. That might be the one which specified no common ground.
highhorse, which brand switch breaks the common negative ground ? Would be really nice to have.
Thanks.
Thanks.
All we're talking about here, I think, is a DPST switch as opposed to a SPST. I suppose the SPST is "safer" by 100% tho because the number of switched contacts is cut in half, and that's why they are prevalent.
I have been running 2 SPST switches (the garden variety type) in parallel to the rx and simply unplugging one of the during charging. It's a pain, but worth it I think.
The duralite electronic switch is a really cool piece of gear and satisfies the requirements with totally independent switches (I think), but is overkill and expensive as it also includes regs. It's reaaaaaly cool tho. https://duraliteflightsystems.com/ac...?product_id=99
#33
I am a big fan of the Smart-Fly EQ-10 with dual A123 2300's. To me, it is a lot of goodies, in one small, redundant package. If the "common ground" is an issue, charge one battery at a time, OR disconnect one of the batteries from the system. This will cure the problem.
Fortunately, most of the new chargers will "sense" this error BEFORE it blows up your charger (and possibly your system). I know the FMA CellPro Multi 4 has saved me a few times.
Again, one battery at a time, or disconnect one battery from the system and you can charge them at the same time.
Chad
Chad
#34
NJ
In my Flash I have 2 A123's going into an orbit power jack. I am using 2 Smart Fly Heavy duty switches. In order for me to charge both batteries at the same time I need to disconnect the batteries from the receiver. Or my Cell Pro 10 tells me "Reverse polarity".
But then again they charge so fast so sometimes I don't bother.
In my Boomer I have 2 A123's going into a smart fly competition 12 with the flag and pin switch.
I can charge both at the same time with out unplugging anything
#35
My Feedback: (43)
On the subject of A123 battery questions, how best to set up a large prop plane - 40% aerobat?
I would like to use a JR 922 Powersafe Rx withtwo A123 batteries, but what is the best way to connect 4 aileron servos?
Use a Smart Fly Expander, oruse a Smart Fly 3D Equalizer, or use Y connectors?
thanks,
freddy
thanks,
freddy
#36
Freddy,
Wrong forum, but again, I am a fan of the Smart-Fly EQ-10 or their power expanders if you don't need the equalizer functions.
Chad
Chad
#37
here's some info about the common ground issue and some chargers that deal with it
[link=http://www.rcuniverse.com/forum/m_9822652/anchors_9822652/mpage_1/key_/anchor/tm.htm#9822652]common ground thread[/link]
#38
My Feedback: (29)
TX
Good thread......
Idon't have a problem charging my 123's one at a time but Istill just wonder how Ihave gotten away with it on the Lions and triton jr's for the past 2 years?
Going out to the garage to scratch my head!!!!! LOL!
#40
My Feedback: (7)
Since you guys are talking about A123's please let me jump in. For my Boomer I got me from 42% base here in Sacramento 2 2,600 2 cells A123's a Blue box ( power distribution ) and a 5,200 Li-Ion 4 cells for the ECU, 2 of their hevy duty charging jacks.
I have no clue to these batts. time to learn something new, I order me a new charger just to be on the safe side, my charger is fine but I don't think I can charge these batts. with it. I'm planing to disconnec the batts. and charge one at the time to be on the safe side.
Freddy, this power dist. has 4 places for Ailerons, These units were designed for big aircraft.
Take a look.
http://www.42-percent-products.com/batteries.htm
http://www.42-percent-products.com/p...on_systems.htm
Take a look.
#43
ORIGINAL: CARS II
Mike
#44
ORIGINAL: highhorse
CARSII:
those batt backer toys might not have a common ground. Have u asked the manufacturer? I think I will call tham Monday.....thanks for the link.
CARSII:
#48
I bought one (108T)....sent it back....the voltage drop was a bit too much for me personally....if I remember correctly, the v drop was close to a volt (.8V) under no load....they do not recommend using a 4 cell pack for this reason....I use 5 cell Nimh packs, but just didnt like the v drop....
Even if I used a batery backer that breaks the ground, I still can't charge unrestricted....I have smoke and lights that connect to the receiver also....I boughtt the Hughes charger and now charge all at once with no issues....charges everything...nicd, nimh, loin, lipo, a123.....
#49
Here is another solution:
I mentioned earlier that I have Duralite 123s. It dawned on me to measure the ohms between the ground contacts for the four outlets of the duralite chgr. OPEN. No common ground. I guess it's actually like four seperate 500ma chargers in one small and ultra light box. The charger is a 12v dc unit that comes with an ac adapter as well, so charging at the field or at home is a snap.
This is good news for me since I love the simplicity of the duralites anyway. Because the balancer circuit is integral to each battery, there is no seperate balance lead.
At 500ma/port, the charger is slow. But I just LOVE the zero-hassle charging. Plug in the seperate charge lead of up to 4 batts of any duralite with lithium chemistry (ion, mag, or fe) and the green "charging light" comes on. When a batt reaches it's fully charged state, the green light goes out ! Could not be easier.
And with no common ground for the charge leads, no unplugging a power lead to charge.
Hope this helps, Don.
