RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Flat Clear Spray?? (https://www.rcuniverse.com/forum/rc-jets-120/10184311-flat-clear-spray.html)
Shaun Evans 12-08-2010 09:33 AM
Flat Clear Spray??
Hi,
For those of you who use rattle-can paint, what's a good flat clear? I used to use Top Flite Lustrekote flat clear, but around 2005, they must have changed the formula because it's just not flat anymore. In fact, it's just a cloudier semi-gloss. Does anyone know of a good rattle-can alternative for small projects? TIA
JackD 12-08-2010 10:22 AM
RE: Flat Clear Spray??
Shaun
I just tried Modelmaster flat and it looks pretty good. let me know if you try them
dubd 12-08-2010 10:31 AM
A friend of mine used the ModelMaster flat on his jet and it looked great.
jmohn 12-08-2010 10:36 AM
It works great and as it gets weathered and beat up from handling it looks just like the real thing too.
Jeff
Shaun Evans 12-08-2010 11:37 AM
Hi,
Thanks, guys. Do you know whether or not it's fuel-proof against nitro?
Jet Blaster 12-08-2010 12:48 PM
1 Attachment(s)
Shaun, The Model Master Flat and Testors Dull Cote look great but dont hold up to Nitro or Kero/JetA. I painted my BVM Rafale, BVM F-4E, BVM F-100D and BVM BobCatwith Tamiya paints and used Testors Dull Cote on one and Model Masters Flat on the other. Sure looks darn good though.
Square Nozzle 12-08-2010 12:56 PM
Many auto paint suppliers will put paint in a spray can for you. I used PPG Flex and Flat on my Yellow F-22 (in an HVLP gun) and it came out looking great. One word of caution with flat paints, at least the PPG stuff. Don't put it on wet like you would a base coat. Spray it on so it's dry looking on application. Not so dry that it's got a rough texture but dry looking. A wet coat will not dry flat looking. It will have a slight sheen. Definately fuel proof.
Shaun Evans 12-08-2010 01:20 PM
ORIGINAL: Jet Blaster
Shaun, The Model Master Flat and Testors Dull Cote look great but dont hold up to Nitro or Kero/JetA. I painted my BVM Rafale, BVM F-4E, BVM F-100D and BVM BobCat with Tamiya paints and used Testors Dull Cote on one and Model Masters Flat on the other. Sure looks darn good though.
Wow,
I agree. Those look great. So what happened when it didn't hold up well, did it just smudge off? Were you wiping/cleaning regularly or right after a spill? Part of the issue is I'm doing a simple, inexpensive paint job for a customer, and I'm applying decals (sticky-back) over glossy paint. I use the glossy to get a good, bubble-free adhesion on the decals. When I'm done, I usually go over the whole thing with Lustrekote flat clear, but as I said, that stuff doesn't seem to be flat anymore.... [:o]
Jet Blaster 12-08-2010 01:48 PM
Dont get me wrong, it will be fine for many, but over time, it has its drawbacks. Example: Areas aft of fuel vents and wing areas where Hopper Tanks are placed will smudge/erase the flat clear. I usually keep my scale jets for approximately 2 years and purchase something new. The product/s held up okay after 2 seasons. If the client wont be flying much, then this would be a great way to go as long as he/she understands what can and will happen, once Jet A/Kerosone and Nitro fuelsmake contact with the product/s. I am currently finishing up another BVM F-4E in a Vietnam camo scheme and I will use Tamiya spray paints for camo base andAutomotive clearcoat (with matting agent)as top coat. I think this will hold up much better over long periods of time and now that the market has gone to craps, I plan on keeping most of the jets I own today for awhile. http://www.rcuniverse.com/forum/js/f...wink_smile.gif
Mach1 12-08-2010 02:00 PM
1 Attachment(s)
I used MM Dull Cote on my F-16. It really gives a nice flat finish.
Jet20 12-08-2010 02:56 PM
Sean,
I've used the model master and testors clear coats in years passed. Though it's easy and gives a nice flat finish, I have found that in areas of frequent handling, the clear will begin to wear away and in some cases just cleaning the airplane with windex or similar can cause areas of wear too. Also, it will yellow in the sun over time. It's not hugely noticable until you have areas that require touchup. You'll never be able to match the paint up using the exact same paint you painted the model with. Though, if you touch up the paint along panel lines, it'll give you some nice color variation. I should note that I've only used it on my smaller electric birds.
In recent years, I've come to use a non-yellowing lacquer clear which I like a lot. It comes in a satin, but the key is to kind of dust it on and then hit it with a light scotch brite pad to finish it off. This works great for everything except glow. If you're clearing for glow, then you need to use a two part clear coat so that it's fuel proof. The nitro in the fuel is pretty harsh on paint finishes.
Chris
chrigui 12-08-2010 11:11 PM
For best solution i use Lechler products...
2k matt or best "satin"
Vincent 12-09-2010 02:11 AM
Krylon makes a "matte" flat clear, i have used this in the past and was happy with the finish and durability.It seems to work on any type of painted surface, i have found this matte clear at Ace, Michaels or Jo-Anns crafts stores.
Vin...
chrigui 12-09-2010 02:26 AM
ciao vinc.... come stai?
Vincent 12-09-2010 03:53 AM
Sono buono...e voi??
chrigui 12-09-2010 04:15 AM
tutto bene
now i will build derjet 1:5 VAMPIRE...(arrived 2 weeks ago)
Mike06659 12-09-2010 06:50 AM
I was thinking about using Rustoleum on my next project. Pick my colors and then clear it all with Rustoleum.
Does anyone have experience with this??
Vincent 12-09-2010 07:23 AM
ORIGINAL: Mike06659
As long as you stay with all rustoleum products it will work fine.
V..
Mike06659 12-09-2010 08:49 AM
V,
Thank you
It just makes sense it's available everywhere
tony0707 12-09-2010 09:24 AM
HI
I DO KNOW that rustoleum gloss white and gloss black are fuel proof the scue numbers with a lot of 7's in the number are fuel proof per the rustoleum company info is the clear fuel proof ?
FalconWings 12-09-2010 02:00 PM
ORIGINAL: YellowAircraft
Hi,
use whatever clearcoat you can find and works better for you and amke sure you put enough to protect your decals. Then do an 800 grit wet sand. You can get it as flat as you want.
I ahev an F-16 that's dead flat, and though it looks very scale like, cleaning it is a pain. If you stain it with your fingers, they will remain there. for a while.
David
extra 300 12-10-2010 07:27 AM
David,
Do you mean to say that you can use a twin components glossy clearcoat and still turn it flat by doing a 800 grit wet sand??
Thanks regards,
FalconWings 12-10-2010 10:08 AM
ORIGINAL: extra 300
David,
Thanks regards,
Yes sir. I think a lot of Pros actually use this technique.
I just wet sanded my bandit which had a high solids PPG Clear on it (high gloss) and it looks dead flat now, but slick enough to allow for a good wipe down if needed.
On my next scale jet I will use this technique vs the flex n flat agent, which makes the model dead flat but impossible to clean.
David
Shaun Evans 12-10-2010 02:41 PM
Hi,
Doesn't the 'flat' that you achieved by steel-wooling go away as soon as it gets anything oily on it? That's been my experience...
SPLIT S 12-10-2010 03:49 PM
Any flat finish can get the shiny spots if something oily gets on it. While sanding the clear achieves the "look", you have actually opened up the finish and can make it more prone to the dreaded spot. In can be cleaned though, think of it from a car painters (me) standpoint. The last thing I do before paint on a sanded (flat) finish is to de-grease it. No shiny spots what so ever. Invest a little in some final wipe, not a regular wax and grease remover (DX394 works great) and use that to clean the finish when needed.
Dan
FalconWings 12-10-2010 06:23 PM
Hi,
you mean just like real aircraft? Yes.
Shaun Evans 12-10-2010 07:41 PM
LOL,
No, I don't mean like real aircraft.... I mean like flat ones that are shiny wherever they've been touched :D
Shaun Evans 12-13-2010 04:38 PM
Hi,
Has anyone used Lustrekote Flat Clear recently? Could it have been a bad batch (that lasted for years...)? If you've used some lately, how flat was it?
FalconWings 12-13-2010 05:34 PM
Just sand it and stop touching it ;-)
And I actually think you're the only one who still uses that crap. I always thought Minwax Satin Polyurethane does a better job than LK.
