RE: P70SE or P100
ORIGINAL: Kenrico ORIGINAL: Gary Jefferson I guess by logic the P-100 should fall somewhere between the P-80 @ 22 lbs and the P-120 @ 28.5 lbs. Kenrico, since you just started flying turbines I doubt you remember, but the P-80 was a 17lb thrust turbine at one time. Jetcat made improvements and the P80 went to 18lbs, then 19lbs, and up to 22lbs where it is at now. The great thing is that the P-80 has remained just as reliable as it has always been even though the power has increased by five pounds over the years. I would imagine the P-60 will be around for a long time because of the segment of the market it fits. I have owned several P-60's over the years and they little jewels. One of my favorite turbines. hope i explained myself clear enough for you guys[sm=confused.gif] A dialed down p-100 [sm=bananahead.gif] jajajajajajaja !! |
RE: P70SE or P100
Wilcox is da man, but I hope they have one at FJ 2011 that they can stick on Carlos's calibrated stand, and send one to Olivier Nicolas to test and publish results in RCJI performance comparison chart, where the only JC that hits the advertised thrust nuts on is the P-200SX at 52lbs.
RE: P70SE or P100
Will the P-100 require different on-board equipment? I have a model with a P-70 which would greatly benefit from a P-100. It would be very nice if I could simply swap turbines and perhaps adjust some programmable parameters. Is this a possibility or a turbine newbee fantasy?
Thx sp |
RE: P70SE or P100
I dont think they have decided on the electronics package at this time. There was talk of it coming with a pump like the P20 (electronics,valves in the pump,magnetically coupled, no seal) and the small ECU. Thrust is going to be around 24-25 pounds but they had some issues so who knows what the final will be. Scotty
RE: P70SE or P100
The last info we got from Bob was 29lb was "the goal", but hasn't been achieved. Also even though it is smaller then the P 70, it will be heavier.
RE: P70SE or P100
I wonder if they are picking up a few extra pounds by spinning it faster, getting up on the steep portion of the Power vs RPM curve, possibly with a new machined compressor. My Wren SS hits 160 K, with a sharp increase in power from about 130K upwards to max RPM.
RE: P70SE or P100
cant wait to see the P-100 specs.
| All times are GMT -8. The time now is 03:51 AM. |
