Anyone else have.....
........leaky brakes in cold temps ATthe o-ring?
Setup is Tam F-16 wheels and brakes (Ibelieve the gear is Cermark because the retract frames are red? but the wheels are the white painted ones) Of course the BVbrakes on my Bobcat do not leak at same temp but obviously the tolerances are tighter. Ican confirm the cause because Ican heat the assembly with a hairdryer and it all but goes away. |
RE: Anyone else have.....
1 Attachment(s)
Smitty,
I've got the same setup (Tam F-16) but the brakes aren't leaking in the cold. Mind you, by cold here in Phoenix I mean 50F. The orings are also totally loaded up with grease so that may be a contributing factor too. HNY to you and Mrs Smitty. Regards, Jim |
Mrs Smitty? Ya dog! I thought you had learned your lesson.
haa haaa David!! i told him...two scoops of vanilla foorrrrreeeeeeevvvvveeerrrrr!!!!
Smitty,
I have a Cermark F-16 and had the same problem until I switched the o- ring material. Either of these have proven successful from McMaster Carr EPDM o-ring: 9557K289. $9.24 for 70 Or Flurosilicon o-ring: 8333T336 around 10 bucks for two. Don't forget some o-ring lube. 9463K33 Regards, Mike |
ORIGINAL: yeahbaby haa haaa David!! i told him...two scoops of vanilla foorrrrreeeeeeevvvvveeerrrrr!!!! Ya'll leave my little buddy alone !!!! :D His girdle shrinks real quick when his toys ain't working right !!! When mine don't work right, I just get him to fix it !!!!:D:D Let's al plan Waco in the next few weeks !!!! I got to hear all the stories from the desert !!!! Danno |
He has no stories..... just same garbage can mouth http://www.rcuniverse.com/forum/js/f...wink_smile.gif
Molnar - thanks for your contribution to this thread - Ijust ordered from MC! Your part numbers made it a 30 second affair! Any advantage to one over the other material-wise? |
1 Attachment(s)
haaa big baby.....brakes? we don't need no stinkin' brakes:D
can't wait to break in your new trailer LOL |
ORIGINAL: smitty1001 He has no stories..... just same garbage can mouth [img][/img] Molnar - thanks for your contribution to this thread - I just ordered from MC! Your part numbers made it a 30 second affair! Any advantage to one over the other material-wise? Regards, Mike |
| All times are GMT -8. The time now is 01:24 AM. |
