RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   HotSpot pics needed (https://www.rcuniverse.com/forum/rc-jets-120/10574089-hotspot-pics-needed.html)
Johnny9390 06-14-2011 02:39 PM
HotSpot pics needed
Anyone have pics of their hotspot installation? Also need pics of what you did to hold canopy to fuse?
G4guy 06-14-2011 03:10 PM
RE: HotSpot pics needed
1 Attachment(s)
:D Sorry, I couldn't resist..............
I will check to see if I have any of the interior.
Johnny9390 06-14-2011 03:33 PM
Ouch! What turbine did you have in it? Let me know when you go through it and decide what you're gonna do with the extra parts that made it
G4guy 06-14-2011 04:30 PM
1 Attachment(s)
I had a Mercury in it that was turned up to 152,000. The HotSpot was a rocket. Amazingly the turbine and ECU survived. I always wrap it in heavy foam. I had 3 Dudro tanks, 1 50oz and 2 24oz on either side, plus a 6 oz header in front of the main tank.
No Parts survived, what do you need?
Ron
Randy M. 06-14-2011 06:06 PM
1 Attachment(s)
I sure miss mine. I have a few pics but my install was not the cleanest.
DelGatoGrande 06-15-2011 10:12 AM
1 Attachment(s)
O yes the hotspot:eek: ...me baby fly with a p160sx nowdays!
http://www.rcuniverse.com/forum/m_88...tm.htm#8887487
i use this spring pins on the rear of the canopy to hold it down..use the forum search for "hotspot" there is loads of info and photos!
http://dreamworksrc.com/catalog/prod...roducts_id=990
goodluck[8D]
cmjets 06-15-2011 11:43 AM
1 Attachment(s)
Hello friends::)
I have the molds...:D:D:D as soon as possible I will have another Hotspot.
I had 2 Hotspots, it is a pretty model.
https://picasaweb.google.com/cmjets2007/HotSpot#
BR from Sapin.;)
Carlos Márquez.
_______________________________
http://cmjets.blogspot.com/
Moerig 06-15-2011 12:36 PM
ORIGINAL: cmjets
Hello friends::)
BR from Sapin.;)
Carlos Márquez.
You make them right? ARF? Finished? Tell be you sell them!
Moerig 06-15-2011 12:37 PM
ORIGINAL: G4guy
You forgot the "remove before flight" thing!:D
Johnny9390 06-15-2011 01:48 PM
How much would you charge to make a kit?
cmjets 06-15-2011 11:38 PM
Hello:
You have a PM.;)
Carlos Márquez.
Johnny9390 06-16-2011 07:30 AM
What Servos did you guys use for the elevons? Will Jr 4721 be enough for the flying surfaces or do I need to go higher torque? I was gonna use two for each.
Johnny9390 06-16-2011 07:47 AM
Or what about Hitec HS5645MG, I was looking for the 5945 but I didnt see them for sale anymore. Whats the difference?
Gary Arthur 06-16-2011 10:50 AM
1 Attachment(s)
I used JR8411
DelGatoGrande 06-16-2011 11:30 AM
hs 5645mg have litle more gear gap...so if you run one per aileron (two aileron in one wing) is not good idea...two per wing with one aileron on the wing is better cause while maching you can reduse gear slop.. but use 100% end points so you wont kill your servo torque
..i just like overkill and see servos as future investment so since i fly with a p160 and my hotspot is not "stock" i have twin hs7955tg per wing (one aileron per wing) and feed them with a PowerBox Evolution.
my2c
Johnny9390 06-16-2011 11:49 AM
I like the idea of just having one airlieron. Unfortunatley I bought the airplane built and in primer and this one has split elevator and ailerons.
cmjets 06-16-2011 12:56 PM
Hi::)
And why you no glue it, for make only one ??? woud be possible ???
Br from Spain.;)
Carlos.
Johnny9390 06-16-2011 01:08 PM
Anything is possible but the problem I see is that I would still need two servos for each because the glue joint would prob not be as strong even if it glassed over. I might just an whole new aileron. Was just trying to avoid that.
For the people that use the split elevator and ailerons, do you actually use "separate" elevator and ailerons or use the two serrate peices as elevons and have them split for redundancy? I dont know if I explained it correctly. :-)
BaldEagel 06-16-2011 01:14 PM
1 Attachment(s)
I don't have a hotspot, but do have a CARF Rookie witch is similar, most that have combined the four elevons together seem to put a piano wire rod in the TE of the surface and Hysol them together, personally I have kept them separate and powered each of the four with Hitec 7955's as also the full vectored thrust tube.
Hope that helps a bit.
Mike
