RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Hotspot Throws Needed (https://www.rcuniverse.com/forum/rc-jets-120/10630088-hotspot-throws-needed.html)
basimpsn 07-20-2011 04:59 AM
Hey guys im looking for throws Elev, Ail and CG, Already did some search and found conflicting information. I know the hopspot needs some up eelevator to start with, not sure if its 5mm or 8mm.
Thanks for your help
Basil
POWER JET 07-20-2011 06:44 AM
RE: Hotspot Throws Needed
It's 8mm,but i suggest you to start with 5mm and then trim up elevator if needed.
On my Hotspot started with 5mm and i didn't trim not even one single click!
Kingtech 80 was the turbine on it.
basimpsn 07-20-2011 09:10 AM
Thanks for the Info ;) I will try 5mm first. As power K170k just kidding,,,are am I [8D].
DelGatoGrande 07-20-2011 09:14 AM
with P160sx at my gallery and videos in youtube
basimpsn 07-20-2011 09:19 AM
DelGatoGrande I saw couple of your video very impressive ;) What is your max throws on Elev and Ail ?
Zagzoo 07-20-2011 06:14 PM
I have the single rudder version of the hotspot (flash), from the nuetral postion (5/16 up is now neutral).
These are the starting points from the manual:
elevator is 1 1/2" inch +/-
ailerons is 1" inch +/1
rudder is 1"+ inch (or what ever you want) +/-
I fly with 1 1/4" of elevator, 3/4" ailerons
basimpsn 07-21-2011 07:21 AM
ORIGINAL: Zagzoo
elevator is 1 1/2'' inch +/-
ailerons is 1'' inch +/1
rudder is 1''+ inch (or what ever you want) +/-
I fly with 1 1/4'' of elevator, 3/4'' ailerons
Sounds good thanks guys ;)
