Help on 12X!!!!
Allright, I know theres some 12X gurus out there who can help me with a little problem...Im using an 8 channel receiver and Im trying to program my flaps with some elevator mixing. Well there is no flap channel on the receiver so I used AUX 2 for the flaps and just mated it to the flap switch. Well now I cant use the flap system( #66 ). Is there any way of using that system with no flap channel?? The receiver is an AR8000..Any help would save me more hours of frustration..Thanks
RE: Help on 12X!!!!
Flap channel is usually channel 6 on the receiver. I'm going out on a limb here, but I think if you plug into channel 6 you'll be fine. I've done that on my 12X with receivers that don't SPECIFY channel 6 as anything in particular and always been able to use the flap settings.
RE: Help on 12X!!!!
Like LMX said, the flaps are channel 6.. AKA Aux-1. Then you should be able us Function 66 to set flap deflection as you want on the flap switch and mix whatever elevator you want to each position. That should get you going..
Danno |
RE: Help on 12X!!!!
KFX450
We need more information. Like is this a Jet, with two flaps, two rudders, two aelerons? Are you using match boxes? Brakes, retracts, etc? The 12X allows you to bring in dual flaps, and put them with some variation, but its not just that simple as which channel. John |
RE: Help on 12X!!!!
Thank you Jeremy and Danno that's what I was looking for....
Indub....just putting together a habu 32. No matchboxes etc.. Looks like I got my answer. Thanks for the help everyone |
RE: Help on 12X!!!!
ORIGINAL: KFX450 Thank you Jeremy and Danno that's what I was looking for.... Indub....just putting together a habu 32. No matchboxes etc.. Looks like I got my answer. Thanks for the help everyone KFX, Let me know how you end up on the elevator mix and which direction... I'm building one of those right now for a customer. Any help will save me a little time !!!!! ;) Danno |
RE: Help on 12X!!!!
No problem Danno..Plugged it into AUX 1 this morning and it worked like a charm. I just finished it and if I didnt work so much it would have already been maidened. Im gonna go with the recommened throws on the elevator mix and let you know how it pans out. I read up on it quite a bit on RCG and they were saying it was spot on when flaps deployed..I will be taking it with me this Sunday for one of our jet gatherings, I will keep you in the loop..
RE: Help on 12X!!!!
Have another 12X question..Still trying to get use to it...
I have my rudder mixed with AUX2 ( Nose gear steering)..How to I inhibit AUX2 when the gear switch is up??? IE: canceling nose wheel steering when gear is up but obviously have rudder control..Any help would be appreciated..Thanks.. |
RE: Help on 12X!!!!
[quote]ORIGINAL: rcjetsaok ORIGINAL: KFX450 Let me know how you end up on the elevator mix and which direction... I'm building one of those right now for a customer. Any help will save me a little time !!!!! ;) Danno Mike |
RE: Help on 12X!!!!
ORIGINAL: KFX450 Have another 12X question..Still trying to get use to it... I have my rudder mixed with AUX2 ( Nose gear steering)..How to I inhibit AUX2 when the gear switch is up??? IE: canceling nose wheel steering when gear is up but obviously have rudder control..Any help would be appreciated..Thanks.. |
RE: Help on 12X!!!!
Well I'm hoping someone can enlighten me...I'm ruining my steering linkage
RE: Help on 12X!!!!
I don't have my transmitter in hand just now , but I believe on the first page of the mix setup , where you specify master and slave, there is a box you can check that says " and" here is where you want to go the the gear switch and turn the "and" and "gear" on. I believe this will give you what you want.
Shepp |
RE: Help on 12X!!!!
Thanks Shepp. I will give it a try tomorrow and let u know how I make out. Thanks
RE: Help on 12X!!!!
its been a long winter and Im having brain cramps, so hopefully someone can help me..Im trying to get brakes on my right slider switch on the 12x. It seems Aux3 is running my left slider switch. When I go into the Monitor and move the right switch it is not on any channel. Im using a 1222 receiver..Can someone help??? Thanks
RE: Help on 12X!!!!
KFX - you can assign channels to different switches on the 12 (which helps with another solution to the first question). Firstly go in to the system mode, go to device select and make sure AUX 3 isn't inhibited. Then you can scroll across and assign it to whatever switch you want (provided it's not being used for something else - you can just inhibit it if it is).
Also - if you still need the answer to the nose wheel steering thing, I mix the nose channel to the rudder (master). Then assign the mix to the gear switch, when the gear is up, the mix is off so the wheel doesn't move. |
RE: Help on 12X!!!!
Wow..That took me all of 2 seconds to do ..haha..Thanks Andrew..Maybe you can help me with another issue I just had..I had my Elan set up on a 10x last year but now I am setting it up on the 12x..Im trying to mix Rud-AUX2, ruder -nose wheel steering. On my other Jet I have have it as
Program Mix 1 RUDD-AUX2 Pos.0 L+100 R+100 It works so I am figuring its right...When I did this on my elan my steering servo burned right out, got really hot..This just a bad servo?? or did I do something wrong.. |
RE: Help on 12X!!!!
Not sure about that one.
Normally I use a curve mix and just manually set up the extent of the mix to give me the throw I want. |
RE: Help on 12X!!!!
Thanks andrew..I appreciate all your help..:D
RE: Help on 12X!!!!
No problem at all:D
| All times are GMT -8. The time now is 09:56 PM. |
