Weathering
HI all, anyone tried the artists oil paint, and oil of turpentine, as in post 306.
http://www.rcuniverse.com/forum/m_69...Cthread/tm.htm what is oil of turpentine. Rcpete |
RE: Weathering
1 Attachment(s)
Yes I did on my Carf Mig 15
Its easy and works for me!, just follow the directions and you'll be amazed about the effect [8D] Turpentine is just used to thin the paint so you can apply it easier, Frank |
RE: Weathering
RE: Weathering
Is weathering done using oil based paints?? What about fuel proofing weathered surfaces?? More details on this and exact color match to use would be much appreciated.
Regards, |
RE: Weathering
Yes oil paint base...
black colour earth or brown colour |
RE: Weathering
Thanks Chrigui,
What about fuel proofing weathered surface?? is there any need to apply a protective coat over weathered surfaces?? regards, |
RE: Weathering
i hane not paint protection... because i can remove or re-apply the wheathering at anytime
RE: Weathering
Thanks again,
Is there any special precaution to take into consideration while applying weathering? or is it a straight forward operation? If you could just drop a few words wplaining your procedure, would be great. Regards, |
RE: Weathering
[link]http://www.su27.de/seite79.htm[/link]
[link]http://www.su27.de/seite80.htm[/link] |
| All times are GMT -8. The time now is 07:23 AM. |
