RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   MIG-29 3 view (https://www.rcuniverse.com/forum/rc-jets-120/10773464-mig-29-3-view.html)
carl.huxford125 10-19-2011 12:19 PM
MIG-29 3 view
1 Attachment(s)
I am after a 3 view drawing of this mig-29 colour scheme, i have searched for hours and can not find one that is clear enough to use.
If not i open to suggestions for interseting camo based schemes (need a 3 view drawing tho)
Cheers
Carl
carl.huxford125 10-19-2011 12:20 PM
RE: MIG-29 3 view
Oh and close up of the insignias as well would be helpful
Mach1 10-19-2011 02:12 PM
RE: MIG-29 3 view
1 Attachment(s)
Here's one.
carl.huxford125 10-19-2011 02:36 PM
RE: MIG-29 3 view
Cheers, just what i need, just need a close up of the red an white insignia now, i have one of the red, yellow and black one.
H.Dale 10-20-2011 06:39 AM
RE: MIG-29 3 view
Does anyone know where I might get plans for a MiG-29? Any size would be fine as long as I can get the patterns for the fuselage formers. HalAir plans would work if anyone has a set they don't want.
spike223 10-20-2011 05:16 PM
RE: MIG-29 3 view
ORIGINAL: H.Dale
Gianni Alessi in Italy have a great one.I do have a copy.From what I recall it's around 1/6.5 scale
Someone in th US bought the rights of the plans.Anyone can confirm this??
jonastecknare 10-21-2011 03:23 AM
RE: MIG-29 3 view
1 Attachment(s)
Maybe this can be helpful!
Jonas
jonastecknare 10-21-2011 03:24 AM
RE: MIG-29 3 view
1 Attachment(s)
seems i can do only one at the time so here goes!
for some reason i cant post more than two posts in a while (strange!)
If this is what you need more will come! 8pics in all.
Jonas
jonastecknare 10-21-2011 03:36 AM
RE: MIG-29 3 view
1 Attachment(s)
no3 and 4
jonastecknare 10-21-2011 03:38 AM
RE: MIG-29 3 view
1 Attachment(s)
5 & 6
jonastecknare 10-21-2011 03:39 AM
RE: MIG-29 3 view
1 Attachment(s)
Ok last ones!
siclick33 10-21-2011 04:48 AM
RE: MIG-29 3 view
1 Attachment(s)
New toy Carl?
H.Dale 10-21-2011 06:23 AM
RE: MIG-29 3 view
Thanks for the drawings. Will try and print them out.
Hal
jonastecknare 10-21-2011 01:47 PM
RE: MIG-29 3 view
1 Attachment(s)
You are welcome! Im doing a Mig myself. A bit slow but i am at it again after a long break.
Probably gonna use the same schem as Carl!
Fiddling with the cockpit and the slob in the seat. Working on the nose gear at the moment.
Jonas
H.Dale 10-21-2011 02:06 PM
RE: MIG-29 3 view
Jonas
Are you scratch building your MiG? I was wondering what plans you were working from.
Hal
jonastecknare 10-24-2011 03:30 AM
RE: MIG-29 3 view
1 Attachment(s)
Yeah its scratch from my own plans. They are not all that accurate, i found those 3-views after i had drawn mine. Im building i foam and will use DF with IC engines. Performance will be poor i know, but so am i. Anyway, at 1/5 i think it will be pretty cool.
Jonas
H.Dale 10-24-2011 07:03 AM
RE: MIG-29 3 view
Jonas
What did you use to make the patterns for your fuselage bulkheads and rib patterns?
Hal
jonastecknare 10-25-2011 02:06 AM
RE: MIG-29 3 view
1 Attachment(s)
I have this signcutting machine, I found that by replacing the knife with a ballpoint pen i could get pretty good fullscale drawings.
Otherwise i use 4mm MDF board or where there is plywood bulkhead i ssssimply drew on to the plywood. The Fuse is pretty much sanded to shape. Only bulkheads where engines/landinggear and other strongpoints dictates a need. Otherwise just foam!
Jonas
