RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Stomped on hinging (https://www.rcuniverse.com/forum/rc-jets-120/11004317-stomped-hinging.html)
rc4flying 03-17-2012 01:48 PM
Stomped on hinging
1 Attachment(s)
HELP !!!!!!
Hello guys,
Well, I am in the process of building my first jet. A Pirotti "Tuono".
All the hinging is top hinged and done as the kit comes from the manufacture. But the rudder has to be hinged.
I am stomped as to how to cut and install this type of hinging. The rudder has a long pin pre-built into the rudder and I have to cut into the rudder for the offset hinges. Here is my problem. Do I install the hinges at a 90 degree angle to the pin hinging as in photo #1, or on an angle that is the same as the top and bottom of the rudder as in photo #2 ?
Thanks.
rhklenke 03-17-2012 02:01 PM
RE: Stomped on hinging
The hinges *must* be 90 degrees to the hinge line between the rudder and vertical stabilizer or they will bind.
Bob
Boomerang1 03-17-2012 03:02 PM
Bob's correct, must be 90 deg to the hinge line.
It's surprising to see that method of hinging on an ARF, it's usually
a method the scale guys go to a lot of trouble to achieve - cool! [8D]
I take it the pin slides out to mount the rudder?
John.
rc4flying 03-17-2012 05:42 PM
ORIGINAL: Boomerang1
John.
Thanks guys, 90 degrees it is. Will install tomorrow. It just had me thinking and did not want to be wrong. Better safe than sorry.
Yes, there is a long pin to remove the rudder surface.
