RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Can I extend the jetcat ecu wiring? (https://www.rcuniverse.com/forum/rc-jets-120/11034159-can-i-extend-jetcat-ecu-wiring.html)
siddus74 04-09-2012 03:40 AM
Can I extend the jetcat ecu wiring without any detriment?
Scott.
Nick Yuhasz 04-09-2012 03:48 AM
RE: Can I extend the jetcat ecu wiring?
I did on my FEJ A-10 with older gas start JetCat P-120's (ver. 6.x ECU's). I made up longer "phone cables" that carry thermocouple and rpm data. Also, extended the power wiring from the ECU to the turbine. The total length from ECU to turbine was about 6.5 feet. Flew the A-10 multiple times last year without issue.
Nick
siddus74 04-09-2012 03:53 AM
Nick thanks for the reply ... ive extended the phone type, this is a P20 loom ... any advice any one?
Sott
kimhey 04-09-2012 04:07 AM
It can be done, but Jetcat will probably not reccomend it (and you will most likely say goodbye to the warranty) ,probably to minimize user-caused shutdows and failures due poor soldering skills. If one has the knowledge and skills, I see no problem doing this;)
Shoot jetcat an email, and hear what the say..
Dave Wilshere 04-09-2012 04:12 AM
Scott
Yes, you can. Max recommended length is 1.5m Turbine to ECU and if you need to extend the ECU to Fuel Pump 1.0m. But its best to keep both as short as possible. JetCat don't yet offer longer cables, but I have asked them to look into it...
regards
Dave
siddus74 04-09-2012 04:23 AM
Dave, thanks .. thats the answer I was after ... I have the same guage wire ...
Scott
bcovish 04-09-2012 05:04 AM
ORIGINAL: siddus74
Scott.
If you do extend the data cable be sure you get the polarity correct when you install the connector.
readyturn 04-09-2012 08:25 AM
ORIGINAL: bcovish
That is for sure.......... [&o] Yah, don't ask..... $$$$
siddus74 04-09-2012 09:39 AM
i just cut the loom in the middle one by one and joined them one by one .... cant get it wrong then ... tried both extended looms on a dry run ont the bench .. he p20s go through the complete start sequence no problems ...
Go one then, how much?
Scott.
