RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   JR TX (https://www.rcuniverse.com/forum/rc-jets-120/11054158-jr-tx.html)
rcpete347 04-23-2012 04:32 PM
JR TX
1 Attachment(s)
HI all, can't believe, I can't find the answer in the manual but after setting up a gyro, I got looking a the main screen on the JR 12x, and do not know what the upper trim graft does,with 12 and 16,see pic.
Anyone know.
Rcpete</p>
KC36330 04-23-2012 05:13 PM
RE: JR TX
it's the eyebrow trims, if they aren't assigned to something they do nothing but beep as you bump them :)
rcpete347 04-23-2012 05:17 PM
RE: JR TX
HI, thanks, it's funny, how they ended up with 12 and 16, when they have never been assigned.
Thanks Rcpete
Bob_B 04-23-2012 07:43 PM
RE: JR TX
that's there position away from Center not a channel assignment.
John Redman 04-24-2012 05:39 AM
RE: JR TX
As Bob stated, it is a position away from center.
Also these trimmers can be used as momentary function or as selectable function on any 12X. If you purchased your 12X when they first came out and have never sent it in you will not have the momentary function and it needs to come back to Horizon for a firmware update. Only necessary if you want it.
There is an addendum regarding this here. http://www.horizonhobby.com/pdf/JR_1...l_Addendum.pdf
You can check the addendum and then check screen 83 to see if you have the updates firmware.
rcpete347 04-24-2012 07:40 AM
RE: JR TX
1 Attachment(s)
Thanks Bob and John, my 12x was upgraded, and great to see this extra function.
So I have learned , this ear switch, can be used for a trainer switch, a on/off switch.
So back to my originall question, the screen with 12/16 ?, and how do i 0 it, where in the manual, is it explained.
Rcpete
Dave Wilshere 04-24-2012 07:45 AM
RE: JR TX
Pete
You should just be able to drive them back to 0...
Dave
Greg Wright 04-24-2012 08:02 AM
RE: JR TX
Pete,
You can also turn them off completely so if you do hit them they will not move from center. I have assigned the right momentary switch as my timer start button after i have inhibited the switch.
seflyer 04-24-2012 08:03 AM
RE: JR TX
you can make them momentary buttons under trim system,either on or off, but they can be run out either direction whether set to momentary or not. they cannot be disabled that I have found.
Kevin
KC36330 04-24-2012 08:16 AM
RE: JR TX
ORIGINAL: seflyer
Kevin
sure they can, under Trim code set flap and aux trim steps to 0 and they won't move.
seflyer 04-24-2012 08:20 AM
RE: JR TX
ok, cool did not think about that. you're right, just dit it.
Kevin
Greg Wright 04-24-2012 10:29 AM
RE: JR TX
Or you can go to the two columns on the right of the flap and aux trim and turn them from on to off and they will not move at all.
seflyer 04-24-2012 10:46 AM
RE: JR TX
ok, so the left column turns the switch on or off and the right changes it from momentary to normal. learn something new everyday., lol
Kevin
John Redman 04-24-2012 11:11 AM
RE: JR TX
Talked about in the addendum I listed prveiously.
seflyer 04-24-2012 11:15 AM
RE: JR TX
never needed to disable them, I love those things, one is for my timer and the other for misc. functions that I use on a few planes. maybe I should read the instructions once in a while.
Kevin
KC36330 04-24-2012 11:39 AM
RE: JR TX
ORIGINAL: seflyer
......... maybe I should read the instructions once in a while.
Instructions are just the manufacturers suggested way you use it, they aren't mandatory.
