RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Elevator & Rudder extensions ??? (https://www.rcuniverse.com/forum/rc-jets-120/11089499-elevator-rudder-extensions.html)
Jetfan20 05-21-2012 04:30 PM
Hi All,
What method do you guys use to protect the servo wires and rudder servo from the heat of the tail pipe? Aluminum tape, BVM heat shield, the heat blanket or all of the above?
Thanks for all your help in advance!
racer8297 05-21-2012 04:52 PM
RE: Elevator & Rudder extensions ???
I use this:
http://www.mcmaster.com/#catalog/118/819/=hmyci8
Jim
Ayrtonsenna 05-22-2012 12:21 AM
I'm with Jim...I also use a similar product
CraigG 05-22-2012 02:55 AM
Additionally, route the servo wires along the sides and away from the top of the fuselage to the max extent possible. Generally speaking, you won't need heat protection along the sides unless they are very close to the tailpipe.
Craig
S_Ellzey 05-22-2012 04:52 AM
Aluminum tape over ceramic blanket. The aluminum tape, if left natural finish, reflects radiant heat and the blanket provides some protection against conductive heating.
Xairflyer 05-22-2012 06:49 AM
Same as Jim you can normally get it on eBay
