Skymaster Hinges
Does anyone have any luck using the hinges that come with a Skymaster kit????
The ones that are knock offs of Robart hinges...... I have always used robart instead of the stock hinges.. On the BD 5 I am building the rudder hinges came glued into the rudder only. Rather than drill them out and rebuild rudder to use robarts I just used the stock hinges... Now that I have to rudder glued to the fin. I am seeing alot more play in the hinge pin than I am used to with Robart Hinges... The play is a in and out movement.... Should I worry these hinges are going to wear out in 3 flights or will they be ok..... Problem is now that it is all glued.....I dont even know what I would do to change the hinges. Thanks for the input Bill |
RE: Skymaster Hinges
Bill,
I had similar probs on my 2m VJ. 2/3 hinges snapped, one during installation (with glue drying of course) and the second during radio setup. My recommendation: cut the hinges from the side with a Dremel (just to separate the rudder), and then use a soldering iron to melt the hinges out (I used sharpened brass tubing that just fit around the hinges and drilled them out, but that was a pain), and reinstall with Robarts (they are much more resilient and 'tight'). V/R Dave |
1 Attachment(s)
ORIGINAL: ozief16 Bill, I had similar probs on my 2m VJ. 2/3 hinges snapped, one during installation (with glue drying of course) and the second during radio setup. My recommendation: cut the hinges from the side with a Dremel (just to separate the rudder), and then use a soldering iron to melt the hinges out (I used sharpened brass tubing that just fit around the hinges and drilled them out, but that was a pain), and reinstall with Robarts (they are much more resilient and 'tight'). V/R Dave Those Skymaster hinges are poor/weak imitations of Robarts and have a history of failures. I would not risk using them. Do what Dave suggests and if necessary, cut away a larger area where the old hinge was and add a dowell or hardwood piece to drill and attach the new hinge. Here's a picture of how I did it on my Skymaster big Viper. Craig |
I hate it when I am right....
Down to cut hinges apart... Thanks Guys Bill |
| All times are GMT -8. The time now is 05:20 PM. |
