RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Servos for Skymaster Large Hawk? (https://www.rcuniverse.com/forum/rc-jets-120/11215075-servos-skymaster-large-hawk.html)
ECalderon 09-02-2012 06:03 PM
Hi guys
What servos are you using for the Skymaster large Hawk?
For elevator and flaps I am planning to use JR 8711, but I am wondering if using the same for ailerons and rudder would be overkill. Would JR 8411 work ok?
Regards
Eduardo
Joe Westrich 09-02-2012 06:10 PM
RE: Servos for Skymaster Large Hawk?
I just finished mine and I used 8711 all the way around. I think it is more than need on the aileron and elevator but the 8411 are not that much cheaper than the 8711's So I jused 8711's. Some trimming is needed to fit the 8711 in the mounts, but its not a big deal.
dubd 09-02-2012 06:34 PM
8411s are enough for the ailerons, but I would use a 8711 for the rudder.
ECalderon 09-03-2012 09:25 AM
Thanks for your input guys. I think I´ll go 8711 al arround.-
Regards
Eduardo
jetnuno 09-03-2012 03:24 PM
Hi
I am a Futaba guy and used 9156 for elevator and flaps, BLS451 for ailerons and BLS153 for Rudder.
IMy kit as 2 years old and as not yet been maiden. I have a P160 but the fuel tank is very small-less than 3 liters.
Do you have 1 fuel tank? Did you measured it?
Nuno
Gonzalo38 09-03-2012 03:29 PM
Eduardo:
I'm using 8711's in mine. Same in all the other planes. For the money difference, I don't think the 8411 is worth it.
Boating Bob 09-03-2012 03:51 PM
Why not 8911HV and no regulator.
ECalderon 09-03-2012 04:40 PM
I already ordered 8711 all arround.
I,ll use a powerbox, that regulated to 6 volts, so no need to go to Hv.
Regards
Eduardo
