RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Jetcat smoke pump (https://www.rcuniverse.com/forum/rc-jets-120/11304758-jetcat-smoke-pump.html)
Guillermo Ibanez 11-21-2012 05:01 AM
Jetcat smoke pump
Hi:
I have a smoke pump but I can't get it work
I followed instruction about using the RX mode but I cabt get it to work
Aby suggestion?
BRG
CARS II 11-21-2012 09:12 AM
RE: Jetcat smoke pump
Ok here the first question.
Did you tested the pump by itself using a battery directly to turn the pump? if you did and it works now is time to look at the set up, also you may want to call Bob W. at Jetcat USA or send him a email regarding you problem.
Guillermo Ibanez 11-21-2012 11:01 AM
Connecting a 7.4 V battery directly to the pump will make it start? If it will, then the pump need a switch to stop running once a battery is connected directly.
Or, what do you mean with connecting a battery directly?
I have connected a 7.4 V battery to the multiplex green connector and the pump do not start.
I think it will not start until it receive some kind of signal from the receiver. (I have choosed the Rx option).
Do I need to do any jumper for testing the pump once a battery is connected directly?
BRG
dubd 11-21-2012 11:53 AM
Does the pump "beep" when you hold the button down and turn the rx on?
CARS II 11-21-2012 11:57 AM
That's what I was trying to say, test it to see if it works by itself.
Guillermo Ibanez 11-21-2012 12:10 PM
No
The pump do not beep when I hold the button down and turn on the receiver
ravill 11-21-2012 12:17 PM
I've been a long time Jet Cat lover.
And their smoke pumps are HORRIBLE. I can list all the problems I've had with them, including what you are having but it's really not worth it. Really.
The best advice (I'm sorry Bob W. and crew) is to try to get your money back and buy TWO sullivan skywriters.
Skywriters take a serious beating and work and work and work and work.....
http://i384.photobucket.com/albums/o...s/DSC_0302.jpg
http://i384.photobucket.com/albums/o...anditsmoke.jpg
Guillermo Ibanez 11-21-2012 12:29 PM
Thank you for your advise.
Money back is not possible because I got this pump 3 years ago and never used it. It was in its original package until now.
Any other opinion prior to throw this pump in the trash can?
Jetcat direct support do not reply my posts. Maybe the know about their issues with this pump.
Strange situation because turbine pumps are very reliable don't you think?
ravill 11-21-2012 12:32 PM
Yes, the turbine, brushed motors work very well.
I had multiple problems with the gears getting gummed up with the JetCat smoke pumps. I.e., its not just with the motor/controller either.
CARS II 11-21-2012 01:43 PM
Doctorcito
You really know how cheer up a company [:@]:D,
Very nice smoke, thick.
Guillermo Ibanez 11-21-2012 05:28 PM
http://www.rcuniverse.com/forum/js/f...sn/biggrin.gifhttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gifhttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gif
dubd 11-21-2012 06:04 PM
I just went through this with a Jetcat pump. I replaced it with a Skywriter.
furloughed ual 11-21-2012 08:24 PM
The pump is great...one of the best on the market for producing great smoke. The problem is the circuit board. Loosen the Allen screws on the pump casing and pull the pump and control board out. Look at the back of the board. Chances are there is a circuit there that you will see has burnt thru. U can reconnect it by soldering a small connector wire. That sometimes works. The other solution most do is to just use an electric motor ESC and connect that to the positive and negative leads of the pump and run it via the ESC. It will produce great smoke this way. I know it's a pain, but a much better and cheaper solution to throwing it in the trash and buying something else.
dubd 11-21-2012 08:28 PM
Thanks for the workaround. I'll pull the board and take a look.
extra 300 11-22-2012 12:13 AM
That's not good news for the Jetcat smoke pump i still have new, bought a couple of years ago....
AFTERBURNER1 11-22-2012 06:13 AM
Take the pump out of the case, solder a "brushed" EFLIGHT 15 amp speed controller to it and you are done...
Used them for years... Work great!
Guillermo Ibanez 11-22-2012 05:40 PM
ORIGINAL: furloughed ual
Thank you
I will give a try
Guillermo Ibanez 11-22-2012 05:41 PM
ORIGINAL: extra 300
Mine is new.Has 3 years in the original package
Guillermo Ibanez 11-23-2012 08:41 PM
1 Attachment(s)
ORIGINAL: Guillermo Ibanez
Thank you
I will give a try
HI:
I dissasebled the pump and found a microchip broken. Where exactly should the small connector wire be soldered? I tested the pump connecting a battery directly to the + and - terminals and it works fine but without speed control
Attached are two pictures, The microchip broken is the one that is on topofthe two that are together
BRG
rcpete347 11-23-2012 08:55 PM
1 Attachment(s)
HI all, Afterburner 1 is right, Jetcat circuit boards are crap, replace with brushed 15-20 amp turnigy speed control, really cheap from Hobby King.
Rcpete
Guillermo Ibanez 11-24-2012 10:22 AM
Well, I took the pump to an electronic technician and he said that this microchip is a diode. He changed it for e new one but the pump did not work.
I am going with the RC Pete suggestion of installing a speed controller.
Guillermo Ibanez 11-25-2012 05:39 PM
OK
I did the RC Pete suggestion:
Just one word
http://www.rcuniverse.com/forum/js/f.../thumbs_up.gifhttp://www.rcuniverse.com/forum/js/f.../thumbs_up.gifhttp://www.rcuniverse.com/forum/js/f.../thumbs_up.gifhttp://www.rcuniverse.com/forum/js/f.../thumbs_up.gif
extra 300 11-25-2012 10:17 PM
ORIGINAL: rcpete347
Rcpete
rcpete347,
Could you please give more details on how exactly did you install the Turnigy ESC (where was it soldered, what parts did you remove from the jetcay smoke pump and how does it all look after the mod.)
Thanks in advance,
quist 11-26-2012 01:42 AM
You solder the esc wires directly to the terminals on the motor.
extra 300 11-26-2012 06:24 AM
Thank you. Therefore, all other electronics should be removed, correct?
