RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   TURBINATOR STAB (https://www.rcuniverse.com/forum/rc-jets-120/11440249-turbinator-stab.html)
RAPPTOR 03-11-2013 02:08 PM
TURBINATOR STAB
:D TURBINATOR STAB INCEDENCE?? STOCK AND OR NEW MODIFIED>>:eek:
Ron Stahl 03-11-2013 02:18 PM
RE: TURBINATOR STAB
I'll check my plans and post the answer asap.
RAPPTOR 03-11-2013 04:43 PM
RE: TURBINATOR STAB
THANKS .. I HAVE PLANS . SAYS 3/4 POS.. POS... TO WHAT?? DATUM OR MAIN WING?? THANKS FOR TIME AND REPLY:eek:
Ron Stahl 03-11-2013 06:51 PM
RE: TURBINATOR STAB
Incidence angles are always measured to the datum plane in my industry as a aircraft fabricator. Angles of incidence referenced between the wing and stab have been titled several things by modelers. Dave Platt explains it as longitudinal dihedral, some call it decalage. I will call Nick in the morning for you and verify where he is measuring it from and report back.
RAPPTOR 03-12-2013 01:24 AM
RE: TURBINATOR STAB
;)WOW .. THANKS SO MUCH.. PLANE TENDS TO CLIMB WITH SPEED INCREASE.. DOWN THRUST ON TURBINE HELPS THIS..IT LOOKS LIKE "CRUTCH " MAKE WORK AS DATUM.. SHOWS 2DEG. POS ON MAIN WING USING IT..DONT WANT TO HAVE TON OF TRIM ON STAB IF I MISS ALIGN.. :D
