RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Installing ElectroDynamics Lights (https://www.rcuniverse.com/forum/rc-jets-120/11598682-installing-electrodynamics-lights.html)
VF84sluggo 05-06-2014 02:37 PM
Great lights, but how in the heck do you install/mount these things? :confused:
Any tips, suggestions, pics, etc. will be most appreciated.
Sluggo
rcjets_63 05-06-2014 03:13 PM
3 Attachment(s)
Hey Sluggo,
I simply cut a hole in the leading edge, installed pieces of light ply inside the wing, drilled a thru hole, and glued the LED in place. See photos below. Sorry I missed you at TG.
Note: The lights come with a wire lead which is about 36" long. At the mid-point in the wires, there is a piece of heat shrink around a small circuit-card board. If you want to shorten the wires, that is OK, but make sure you still install the board as it has a surface mount resistor installed.
Regards,
Jim
http://www.rcuniverse.com/forum/atta...mentid=1993079http://www.rcuniverse.com/forum/atta...mentid=1993080http://www.rcuniverse.com/forum/atta...mentid=1993081
VF84sluggo 05-06-2014 04:59 PM
Thanks Jim. Your method seems like the way to do it, just wanted to make sure I wasn't overlooking something.
The wingtips on my Viper already have recesses/clear covers, so that install should be pretty straight forward. However, installing the upper and lower fuselage anti-collision beacons seem a bit more challenging. I bought a couple of the clear sheets of the various shaped beacon covers - http://www.electrodynam.com/store/product260.html - but I'm scratching my head over how to attach these things and not make it look like a child of 8 did the work (which is usually what my builds look like indeed did happen.)
I also got the landing light with the intensifying lens (wow, does that gizmo work!!), but figuring out how to attach this apparatus to the nose strut is also an engineering hurdle to be cleared.
Yeah, sorry I missed you guys at TopGun. Always a good time hanging with y'all. I just couldn't make the time off from work fit around it this year. Maybe next year. Also a no-go on KY Jets this year due to family vacation plans. The Blue Angels are doing the beach airshow that week, and the family wanted to rent a beach house for the week. Gotta admit, they didn't have to twist my arm too hard.
Cheers,
Sluggo
