door sequencer
Looking for a new door sequencer for my skygate hawk. I came across EVOJET Jettronic Box HV and the EasyDoor HV. Can I have some feedback from people who have used either or both of these? If both are sequencers, why the dramatic price difference?
thanks |
2 Attachment(s)
I'm using one from hobbyking for $12 works perfect with digital servos and have multiple settings and servo throws ,made by assan.
Hi Anurag,
The Jetronic-Box by EVOJET (used to be called ORBIT), is by far the best "Electro/Pneumatic" unit on the market today. I use them in ALL my jets with the PRO-HV Dual Action Valves and PRO-HV Brake Valve. Plus it has a "Failsafe" feature for all the pneumatic's. You will however need the EDT for set-up. If you use the small EDT unit it can also be permanently mounted on-board - if you wish. |
I just use the sequencers in my transmitter.
I have used both UP3 and Jet tronic. No issues with either.
Originally Posted by wfield0455
(Post 11817217)
I've set up my last two models like this… super easy. |
Originally Posted by DrScoles
(Post 11817285)
Originally Posted by tucson
(Post 11817651)
Which Transmitter sequencers are you all using?
(Post 11817918)
I have both Spektrum DX18 and Jeti DS16 transmitters that provide sequencers.
Can you recommend a video that someone has made about setting up the sequencer? Thanks, Stan |
Thank you for the input guys. Appreciate it.
2 Attachment(s)
(Post 11817924)
I thought you had the Jeti. I also have a Jeti and looked at the sequencer but it didn't look that user friendly.
Can you recommend a video that someone has made about setting up the sequencer? Thanks, Stan I've attached a couple of photos of the sequencer I use on my Skymaster/Xtreme-Jets Dragon. It's a very basic setup, open doors, extend gear / raise gear, close doors operation.. Hopefully this will make things more clear. http://www.rcuniverse.com/forum/atta...mentid=2001441http://www.rcuniverse.com/forum/atta...mentid=2001442 |
| All times are GMT -8. The time now is 11:35 PM. |
