JetCat P80SE Methane Fuel Conversion
Hello everyone,
My senior design team and I are in the process of converting a JetCat P80SE to run on methane rather than the recommended 1-k kerosene fuel. We are in the research stage right now and are attempting to really understand how the P80SE works. We found a "How its Made" video on the turbine and it helped us a lot (Model R/C Turbines). Several aspects of the turbine are a bit blurry to us at this point.
Any thoughts, suggestions, or questions are absolutely welcomed! Thanks! |
Why don't you just call JetCat and ask them?
Originally Posted by AndyAndrews
(Post 11880248)
Jetcats Combustion chamber and fuel vaporizers are made in inconel alloy.and the tip of
vaporizers,where the fuel burns,sufer to much erosion. |
be careful you don't know who these people are. if they are working with the air force why come here
1 Attachment(s)
Methane? The methane generating system might be a bit bulky to fit in a normal size model.
Not saying this is the case, but this is how information is obtained soforeign sources can steal technology.
I receive this type of requests for information about UAV's, by email every day, it looks innocent, but many times it is not. Most of all of this stuff is on the internet, plus the poster does not provide enough information about were they are from, what college, etc. |
Dan,
I have a suggest for you, hire another "Design Team" if they can't figure out what they are looking at after dissecting apart a turbine. Coming to RCU for advice is the most preposterous thing an Engineer or head of a "Design Team" could do. I have a suggestion, why doesn't your "Design Team" actually design something on their own, spend some of your government grant money on a thing called Research & Development or R&D for short, instead of trying to steal another manufacturers technology? Seriously, coming on RCU looking for answers on such rudimentary questions like does the bearings come in contact with fuel? When your top designer took apart the turbine did he find a wet sump system with cooling radiators to lubricate the bearings? Geesshhh.... Ghostrider1 out!! |
We've been trying to contact them. No responses yet, but we keep trying.
Everything we are working with isn't classified.
Originally Posted by Dan Reilly
(Post 11880236)
Hello everyone,
Jason |
Originally Posted by bluescoobydoo
(Post 11880274)
Originally Posted by hmjets
(Post 11880273)
Originally Posted by GhostRider 1
(Post 11880348)
Dan,
Your problems are not the internal mettalic materials. Your issues will lie
on using a thermocouple rated for your expected EGT and reprogramming the ECU for the specific energy of methane, and pbly improving insulatiin of components inside the cowl. You need help from JetCat for sure, and that comes at a cost. I would start with an RFI/RFP to JetCat or Dreamworks RC if you are serious. David |
I'm curious, Why you wanto to do this conversion?
The combustion chamber is some alloy of iconel. I can't remember if the needles are on a P-80.
The details of the chamber design control gas flow so who knows how it will run on methane. At least you don't have to worry as much about atomizing the fuel. If it is hard to ignite you can use a spark plug or a piezo ignitor. The fuel system is designed to send some fuel/oil mix into the bearing tunnel. You can inject some sort of lube into the same inlet port, could use compressor pressure to force the lube in, many of the first hobby turbines used this technique. |
As David said Jetcat does a lot of customization for industry and government so just generate an RFQ for what you need. I would address that to JetCat in Germany.
Are you really sure about the temperatures you quote?
http://en.wikipedia.org/wiki/Adiabat...me_temperature John |
wren already sell engines for schools,uni's etc try them
(Post 11880236)
Hello everyone,
| All times are GMT -8. The time now is 03:50 AM. |
