RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Source of large pneumatic fiitngs/hardware (https://www.rcuniverse.com/forum/rc-jets-120/11617394-source-large-pneumatic-fiitngs-hardware.html)
FalconWings 05-19-2015 07:18 AM
I'm looking for a source of 4mm pneumatic tee's, unions, 4-ways. Checked Dreamworks first but they only seem to have straight unions.
Also need adapters from normal line size to 4mm.
Any ideas?
David
hmjets 05-19-2015 07:20 AM
Ebay....
sc0tt 05-19-2015 08:00 AM
Dreamworks does have a good 4mm Festo selection covering most needs - barbed and push-in
http://www.dreamworksrc.com/catalog/...ords=festo+4mm
FalconWings 05-19-2015 08:24 AM
Well, interesting enough went to ebay and found a lot of 4mm air fittings.....apparently they are commonly used on aquariums, plenty of choices. Most suppliers, however, are outside US.
But......the takeaway was "aquarium supplies". Im sure they are good to 5000 PSI. :-)
Thanks Scott, it never occured to look under Festo.
hmjets 05-19-2015 08:52 AM
try smc, is equal to or better than festo , sure you will like it!!http://stores.ebay.com/cpmpneumatics/4mm-Push-fittings-/_i.html?_fsub=3221688011
hmjets 05-19-2015 08:53 AM
http://stores.ebay.com/cpmpneumatics...sub=3221688011
FalconWings 05-19-2015 08:58 AM
hm you are evil!
obrigado!
hmjets 05-19-2015 09:04 AM
De nada ,amigo!!
jetpilot 05-19-2015 10:19 AM
1 Attachment(s)
"4mm push in fittings"
http://www.rcuniverse.com/forum/atta...mentid=2097142
DiscoWings 05-19-2015 11:04 AM
http://www.alliedelec.com/pneumatics...ion=4294965055
DiscoWings 05-19-2015 11:05 AM
e.g. http://www.alliedelec.com/smc-corpor...-00a/70245217/
in the u.s. so shipping is cheap.
flycatch 05-19-2015 11:16 AM
McMaster Carr
FalconWings 05-19-2015 11:32 AM
Originally Posted by jetpilot (Post 12040886)
Scott how do they handle 100psi? No problems so far? I have those, never crossed my mine to use them. :rolleyes:
jetpilot 05-19-2015 12:00 PM
Great for air.
what do you need. ill send you some
Scott
DiscoWings 05-19-2015 12:03 PM
Falconwings, word of advise,
after fooling with 3 different set of gear, from different GERMAN mfgs I can tell you you are better off getting them converted, I have used IQ Hammer, AIr Tech and Behotec 4mm setup... simply not worth it. They take way to much air you will be using like 4 tanks and unless the system is charged to the 90-120 PSI range the power of pneumatic goes down considerably.
On my tomahawk iq hammer gear, i was lucky to get 1 successful retraction and deployment this was with 3 large air tanks 4mm out put, 1 complete cycle dropped it form 110 psi down to 70 psi, I had to set the tam jets fail safe to 75.
The airtech 4mm were a little better ONLY because the gear were smaller, still 20-25 psi drops using 2 large 4mm out put tanks.
Down & locked conversions with there OVERSIZEd 22mm motor made all these problems go away, actually it was cheaper to do the d&l conversions then to buy electronic valves and sequencers, fittings, tubes, and gauges and fill valves.
Wclays 05-19-2015 12:09 PM
http://www.colder.com/Tabid/72/Mater.../Products.aspx
Clay
teebox11 05-19-2015 11:35 PM
Ok, this will really get your goat. Just go to alibaba.com, check festo, smc, pneumatic connectors. You will get to the MANUFACTURERS of these things. THEY SELL FOR PENNIES EACH FROM THE MANUFACTURER AND NOT DOLLARS!!! Sure, you have minimums, but if you use a lot of them for air or fuel, then it doesn't matter. If not, then get a group order together. One thing you want to make sure of is that the connectors have the four little barbs in the compression tube that will grab and keep your tubing secured. Shipping is nothing and can be here in a few days. Even with shipping, the piece might only cost fifty cents, that and a few days beats the hell out of buy it now for $2-10 for one piece!!!! Oh, they will hold the air pressure, I have one tank in my MIBO A-10, pump it to 150psi, and I get 15 or more gear cycles out of it before the gear slows down. Good luck!!!
Harley Condra 05-20-2015 04:12 AM
DreamWorks also has a good selection of SMC fittings; http://www.dreamworksrc.com/catalog/Smc-Fittings
FalconWings 05-20-2015 06:30 AM
Originally Posted by jetpilot (Post 12040946)
Great for air.
Scott
Thanks for the offer Scott, I worked on it last night and had enough Festo's to make it work (and some made by Robart that I had purchased a long time ago and never got to use them).
Appreciate it!
David
FalconWings 05-20-2015 06:43 AM
I agree that going electric is most certainly the safe way to go, but since I have a complete Air System will Failsafe, I'll give it a try. I still have a number of pneumatic door cylinders I have to deal with (6 total).
Right now let me just say that I have doubts my airframe is worthy of an electric conversion. Not very sure what to expect of it at the moment. We'll see how it plays out.
FalconWings 05-20-2015 06:49 AM
Originally Posted by Wclays (Post 12040953)
Asweomse source Clay, thanks for sharing.
FalconWings 05-20-2015 06:58 AM
2 Attachment(s)
BTW, in case you were wondering.
http://www.rcuniverse.com/forum/atta...mentid=2097319http://www.rcuniverse.com/forum/atta...mentid=2097320
