RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Evojet booster 90 issues (https://www.rcuniverse.com/forum/rc-jets-120/11618597-evojet-booster-90-issues.html)
invertmast 06-18-2015 08:43 PM
I picked up a second hand Booster 90 w/ 1:30hrs of run time since overhaul. Im having a problem with the thing getting started. It'll fire up and get into the acceleration stage, but around 22,000 rpm, it flames out and gives the "minT" error. The temps are around 450-550 when it starts accelerating, then as it passes through roughly 15-16k its up at the high 500-low600 temps and the temps decrease as the rpms increase until the temp falls below 500* and then the turbine flames out and gives a puff of white smoke. Battery voltage is fine and there are no visible airbubbles in the fuel line to the engine.
Ive been pulling my hair out with this thing all day and am clueless on what to check next. Any help would be appreciated.
Thomas
Jgwright 06-18-2015 11:03 PM
Thomas
People have reported problems when it is humid and hot. I notice you are in Florida where it is no doubt both. I presume you are using the correct battery .
The manual says Min-T:-
The exhaust gas temperature falls below the value specified under LIMITS 34:EGT-MIN.This is usually caused by air bubbles in the fuel supply system leading to a flameout in thecombustion chamber. Accompanied by considerable smoke emissions.
Solution: Use a better fuel tank system with a membrane fuel clunk or an AirTrap tank.
Min EGT in limits section is set at 250C You can check that this is the case.
I repaired a Booster 80 recently and apart from the many mechanical problems it developed problems in starting that were traced to the thermocouple. This was replaced with an externally mounted one and it has run fine ever since. Working on the Boosters is a bit of a nightmare and there are very few that offer to repair them since the firm that made them closed.
Good luck with it.
John
w4ste 06-19-2015 12:30 AM
Good Luck
When its Humid and hot you going to struggle with an Evojet turbine.
We have the same issue here in South Africa where as the Evojets works at coast but will not work in at High altitude, hot and humid conditions.
chrigui 06-19-2015 04:36 AM
1 Attachment(s)
when hot and high % umidity some engine with fast accelleration ramp report problem...
then modify accelleration ramp.. and startup ramp..
same issue on 90 evo serviced..solved modify accelleration ramp
try to use diesel also
http://www.rcuniverse.com/forum/atta...mentid=2103965
invertmast 06-19-2015 04:40 AM
John,
im using a 4s A123 battery. During the start, the temp never falls below 250 and the fuel system has been gone through twice now, there are no air bubbles.
I got a response from Arno last night and he said the ecu needed a firmware update to "adjust for the aging pump". I dont understand that, but ok. I then asked if a faulty data cable could be a problem as when i first received the turbine and had hooked everything up, the Egt was reading -80 to -100*c, he mentioned that was a possibility to.
chrigui 06-19-2015 04:55 AM
go to AUTOSTART menu --> change ACCE-RAMP from 16s (standard) to 30s or max 40s
invertmast 06-19-2015 04:57 AM
Originally Posted by chrigui (Post 12057686)
andare al menu AUTOSTART e modificare il valore ACCE-RAMPA ... standar è 16s ... provate con double..max è 40s
Thanks, ill try adjusting the acceleration-ramp time.
yeahbaby 06-19-2015 05:43 AM
Good chat yesterday amigo. Sorry couldnt be much help with troubleshooting. I can say with certainty though..... That particular motor does not perform well under hot / humid conditions.
I look forward to seeing some of your projects roll off the assembly line
happy Father's Day
invertmast 06-19-2015 05:48 AM
I look forward ward to seeing some of your projects roll off the assembly line
happy Father's Day
the things we figure out after the fact..... I had a feeling i should of just saved a little longer and gotten a kingtech
yeahbaby 06-19-2015 05:58 AM
Yeah sorry bro. Winter is right around the corner and in cooler temps it's a god lil motor. Perhaps the acceleration ramp might help, just boost airflow with a leaf blower to keep temps down.
My fear is you will spend a greater amount of time near peak EGT while it calibrates.
The leaf blower should help.
invertmast 06-19-2015 06:06 AM
I'll try that to. If murphy keeps working like he has, now that i have the turbine and can get it running, work will end up swamping me to the point that i would get to fly for a few months....
chrigui 06-19-2015 06:12 AM
2 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2103976
http://www.rcuniverse.com/forum/atta...mentid=2103977
Jgwright 06-19-2015 06:47 AM
Thomas
Looks like you had instant help from knowledgeable people, none better than Arno who developed the ECU. Hope you manage to cure it or if not sell it to someone living in cold conditions, like the UK!
John
invertmast 06-19-2015 06:48 AM
Originally Posted by Jgwright (Post 12057741)
Thomas
John
If it doesnt run, ill be having a talk with the guy i got it from and he can deal with it.
invertmast 06-19-2015 09:20 AM
Increased the ramp acceleration all the way to 40seconds and that didn't change anything. At this point i'm thinking the firmware update is an idea and that the pump just isn't supplying enough fuel during the start so once it hits 22k rpm, the starter blows out the flame.
invertmast 06-19-2015 10:48 AM
So I put in a new pump and it accelerates past 22k rpm now. but once it hits 25-26k rpm, it turns into a really pretty flame shot out of the tailpipe... :mad::mad::confused:
This is with both a 3s lipo, 4s A123,16second ramp or 40 second ramp, doesn't make any difference
garyhyde 06-20-2015 05:14 AM
How old is your fuel? To much oil? Just asking
invertmast 06-20-2015 06:27 AM
Its older than i like, but its also is in a sealed container. Oil is the same amount ive always used and whats suggested for the turbine.
Anyways, its been decided that ill be getting a refund and this piece is going back to the seller. Its no worth the my headache or expense to deal with an engine that may or may not operate during summer months and doesnt have any US based support. I'll put the money towards a new kingtech or something.
chrigui 06-21-2015 10:17 PM
OK.. could be various problem.. but it's very difficoult to give a diagnose by web
then you can check
1-kerostart valve leak (then too much fuel)..you can check remove cover or test leak when closed
2-lubrication needle
3-fuel leak into combustion chamber
4-fuel start point too high..
5- other
invertmast 06-22-2015 07:36 AM
then you can check
5- other
This is what it does with a new hausl fuel pump.
https://youtu.be/zfo1Hap35gQ
ill be keeping it as i was made an offer i couldnt refuse to by the original seller. Arno is convinced a firmware update will solve it, so ive got the us. Adapter, new cable set and a pump on order.
George 06-22-2015 07:46 AM
That's good news Thomas!
I bet you wouldn't have bought it if you had asked beforehand. ;)
LGM Graphix 06-22-2015 08:12 AM
I have to ask, what is causing the vibration? I've never seen a jet shake so much on start up.
invertmast 06-22-2015 08:45 AM
That was the pump pulsing. I didnt feel like strapping it back to the mount for the 6th time in 24hrs.
LGM Graphix 06-22-2015 03:05 PM
Gotcha. I had two g booster 80 turbines that I received directly from booster years ago. I sold them both without running them. Those ecu's were Arno's design as well. Sadly both turbines when the new owner ran them did what yours is doing. I agreed to take them back and get them running or send them back to Didi. Didi wanted me to also do the software update and sent me the cable and program. I updated and both turbines ran flawlessly for me. My friend Paul was there as we used his test stand. I sent them back to the fellow that bought them from me. He emailed back stating they were running great and all was well. I later heard through the grapevine a whole pile of bs regarding the engines which I will not get into of course as its over and done with but part of all the issues revolved around, let's call them untruths on everyone involved in the boosters at the time. After the run around I had I will never own another booster product again although I will admit my G Booster 160+ was one of the best engines I ever had. I just can't be bothered to to deal with the companies again. I hope the software flash sorts things out for you!
invertmast 06-22-2015 03:54 PM
yea i hear ya on that, the more research i did once i received this thing, the more frustrating it began, but the deal i was made, i couldnt not keep it. If the software update really fixes it, ill be happy, hell im happy either way now. Having this, even if it means shipping to germany for services, is way better than the Ram and the crap service i got from Carlos and Rti, atleast there is a manufacturer to provide parts.
