RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Transmitter layout. (https://www.rcuniverse.com/forum/rc-jets-120/11629395-transmitter-layout.html)
IFlyEm35 05-11-2016 11:22 PM
Transmitter layout.
So I'm going to try out an 18SZ. Coming from the 12X and XG11 the switch layout is a bit different. I'm curious how other people layout their TX's.
http://i144.photobucket.com/albums/r...po/image_5.png
mackeyjones 05-12-2016 12:29 AM
A- Gear, B- Flaps, D- Smoke on/Off, E - Smoke Trim, F- Gyro Gain, G- Lights,I- Gyro Mode, J Air Brakes, RR Slider - Wheel Brakes Mode 1 Transmitter
sonicboom 05-12-2016 05:09 AM
A gear, B smoke, D flaps, G gyro, J brakes ( Mode 2)
FenderBean 05-12-2016 06:50 AM
A=Flaps I moved a 3 pos switch from the front instead of the two pos for flap up, T/O and Landing Flaps
B= is my condition switch and I tie the gear into this switch as well
J=Engine cut since its a spring switch
I= throttle hold on my Helis nothing much for jets
R slider is my brakes
L slider I use with the gyro
Front switches are for things like the canopy, speed brakes, smoke or maybe gyro stuff
E=trim for the nose wheel since its on a different channel than my rudder in jets
George 05-12-2016 12:46 PM
Set it up as close as you can to the way you had the 12X and/or XG, and that way there's a smaller learning curve to handle in terms of remember what this "new" switch does or doesn't do.;)
