Skymaster Cougar (small) from https://www.pacificrcjet.com/
1 Attachment(s)
Picked up this small cougar for my sons Christmas present. This will be his first jet and he is very excited. Put the order in with Dirk and all went very smooth with great communication. Plane arrived with no damage and was packed well. This one will be powerd by the one and only Kingtech K45.
This plane looks to be a great first jet for people new to turbines. The only down side is no instructions. If anyone has any questions I will do my best to help out. This plane does not cost much more then the Foam planes and its full composite with all panel lines. It also should be very easy to fly like other cougars I have flown. http://www.rcuniverse.com/forum/atta...mentid=2198980 |
6 Attachment(s)
Been cranking on the plane for a little over a week now and its about ready for maiden. This plane can easily be built in 2 weeks of doing a little in the evenings.
Used all power box wire because of its heat resistance. All custom made servo leads so I don't have connectors all over the place. Used spektrum mini servos in tail and for nose steering. Fuel tank is done using BVM Kevlar tank fittings kit. I don't take any chances with the fuel system. Because of the shape of the tank the clunk looks like it has a chance to suck onto the sides depending on orientation. So I cut an extra slot in the bottom of the clunk so it won't slow fuel flow down. Also had my son trying to take old cockpit parts laying around and building himself a cockpit. http://www.rcuniverse.com/forum/atta...mentid=2198981 http://www.rcuniverse.com/forum/atta...mentid=2198982 http://www.rcuniverse.com/forum/atta...mentid=2198983 http://www.rcuniverse.com/forum/atta...mentid=2198984 http://www.rcuniverse.com/forum/atta...mentid=2198985 http://www.rcuniverse.com/forum/atta...mentid=2198986 |
For your son??? I'm going to have to try that one, no honey, honest, it's not for me, I have enough planes. :cool:
Looks big for a 45..What's the AUW?
Originally Posted by txshan130
(Post 12301153)
Awesome! Dylan's smile says it all. Have fun!
I saw a Panther of the same size fly on a 6lb thrust turbine. The K45 should fly this Cougar very
quite nicely! |
Chris, does Pacific RC Jets stock those kits or do they have to order them?
I'm starting to think that this might be a good alternative to the foamy jets for an every-day flyer as you mentioned... I'd want a K60 in mine for the grass field though I think... Bob |
He probably has to order it but would have it drop shipped directly to you I'm sure.
2 Attachment(s)
Originally Posted by rhklenke
(Post 12302013)
I'm starting to think that this might be a good alternative to the foamy jets for an every-day flyer as you mentioned... I'd want a K60 in mine for the grass field though I think... Bob Hello bob hope all is well. You have 2 options. DHL direct so you get it in about or 4 days or wait for a container to come over. Shipping was about $750 DHL. Container would be cheaper but would need to wait. I am very happy with the plane. Its a very good deal for a scale jet. They also did a custom scheme with no up charge. Its ready for maiden. Might do it this weekend. http://www.rcuniverse.com/forum/atta...mentid=2199245 http://www.rcuniverse.com/forum/atta...mentid=2199246 |
Chris,
Thanks for the info. I'm not quite ready to pull the trigger on anything yet, but I am saving for a new jet to add to the fleet and it *must* be grass field capable and easy to transport and assemble, so this might be the trick. Things are going well for me, thanks! I hope the same for you and looking forward to seeing everybody in the '17 flying season! Bob |
What a great plane!! Today was maiden day and 8 flights later could not be happier! We had a very strong 90 degree crosswind with no gyro installed yet to make things fun. Plane flies great with the K45. Flies very scale. Uses a little more runway but then flies good. Perfect plane for pilots new to jets. Going to fly even better with a gyro.
Best part is this plane is just a little more then the foam jets. |
1 Attachment(s)
Originally Posted by gunradd
(Post 12302896)
That is cool! I didn't realize it was close to the size of the foamy Viper. It loos like it flys great! Does it have the main gear doors and the split flaps? What size are the tanks and any idea what the flight time with a K60 would be? Thanks! Bob |
(Post 12302937)
Chris,
That is cool! I didn't realize it was close to the size of the foamy Viper. It loos like it flys great! Does it have the main gear doors and the split flaps? What size are the tanks and any idea what the flight time with a K60 would be? Thanks! Bob No main gear doors and only has the big body flaps. With a k60 I would think 5 mins easy. He would be into the power allot the whole flight for 5 mins and have between half and a quarter tank left. |
Great looking Cougar. Sorry I'm late to the party with my question, but.... where is the CG? I have one that I'm getting close to flying too.
Thanks in advance. |
I have purchased the top rc cougar. I was looking at mini servos. Most are in the 50 Oz range. Is this enough for the elevators and speedbrake/ flaps? Also. Which mini servos have you used. Thanks
Take a look at Hitec HS-7245MH, 72 oz on 6V and 88 on 7.4V, that's what'll be on the elevators of my 88" A-10 and they should be enough for the small elevators of a Cougar.
I used JR NX3421’s for my elevators and flaps. So far so good
| All times are GMT -8. The time now is 11:33 PM. |
